Headlight surface cleaning and height difference
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 16:19 # 1
SZKR
Hi guys;
I have two questions in mind;
1) The left headlight has changed because it was broken, but as seen in the picture, there was an obvious difference with the other headlight. I say that if I take the plastix from this so-called sanding polish only the outer surface, is the problem solved or is there any yellowing on the inside?
My second question is; The back height difference in the two pictures is caused by. Mine and many of the xs I've seen are slightly higher behind, but the angles of the other picture look great. I don't think extra bits were made, I wonder if there was a level difference after 2005 about the back team.
08.05.2020 16:19 # 2
Engin Tepe
2. VEHICLES ARE PROVIDED IN THE VEHICLE. There are few drops
08.05.2020 16:19 # 3
maestro
You can apply water sandpaper for the headlamps (in a circular motion by constantly wetting from the thick to thin) & nbsp; on top of the cake & nbsp; it will not be exactly the same as the other, but there will be a lot of improvement.
08.05.2020 16:19 # 4
gozem
Brother, I applied the headlight polishing process with a lot of sandpaper and polish, 2000-2500and3000no sandpaper and then polish, it was very nice at first glance, like 0 headlight. But after a while it lost its polish feature, it got a matt appearance again. Although it has no roughness when you touch it by hand, it is still matte. I suppose the quality of the polish is also important. also the back in my vehicle is too high
08.05.2020 16:19 # 5
metin
The inside of the headlights is clean, the surrounding part is the polish on the glass. If there is a capillary cracking on the inside of the headlight, do not deal with the outside. Apart from that, if you sand from thin to thin and polish beautifully with the latest meguiars plastx, there is no problem.
& nbsp;
the height of the back is also normal. Don't hang out on him. Even if one person sits back, it goes down. it stays further down when the tank is full
08.05.2020 16:19 # 6
Kemanyak
I think the element in the picture has come down by pulling the hand brake and I think the height difference stems from it. If you use an abrasive (paste) with a nice polishing machine and then start polishing with polish, the problem in headlights will disappear. Car washes doing 20 lira.
08.05.2020 16:19 # 7
AliOzagan
I would appreciate if you share your result if you clean your headlight, mine needs cleaning, but I am afraid I will make it worse & nbsp;
08.05.2020 16:19 # 8
Serdar
I do not know what is new in Turkey, but I think the new price of raw farla vehicle too tight unstopped digerini the refresh will be a great picture :)
08.05.2020 16:19 # 9
Serdar
[QUOTE = Kemanyak] 1. I think the element in the picture came down by pulling the handbrake, I think the height difference stems from it. If you use an abrasive (paste) with a nice polishing machine and then start polishing with polish, the problem in headlights will disappear. Car washes for 20 liras. [/ QUOTE]
I think the user did not pull the handbrake because it is understood that the user seat and the back seat are full when looked carefully. There are people sitting inside and the brake lights are on, your car :) or what am I dreaming about :)
08.05.2020 16:19 # 10
If you bought a pole or two angels, the foot was broken and I heard it for the first time.
08.05.2020 16:19 # 11
Kemanyak
[QUOTE = Serdar] [QUOTE = Kemanyak] 1. I think the element in the picture came down by pulling the handbrake, I think the height difference stems from it. If you use an abrasive (paste) with a nice polishing machine and then start polishing with polish, the problem in headlights will disappear. Car washes for 20 lira. [/ QUOTE]
I think the user did not pull the handbrake because it is understood that the user seat and the back seat are full when looked carefully. There are people sitting inside and the brake lights are on, your car :) or what am I dreaming about?) [/ QUOTE]
Congratulations, when we are buried directly in the tire fender :-))) We missed the elements :-))) The car is full. Even a little collapsed.
08.05.2020 16:19 # 12
Kemanyak
[QUOTE = AliÖzagan] I would appreciate if you share the result if you clean your headlight, mine needs cleaning but I hesitate to make it worse & nbsp; [/ QUOTE]
206's problem stems from inside :-)))) Disassemble the headlights. If you throw a piece of cloth as much as a finger and shake it thoroughly with a nice cleaning detergent (it will not be abrasive), you will see the black work flowing through it with your eyes. & Nbsp; There was yellowing in my headlights but it was like a coal reservoir. It officially regained its brightness on the first day.
08.05.2020 16:19 # 13
AliOzagan
[QUOTE = Serdar] [QUOTE = Kemanyak] 1. I think the element in the picture came down by pulling the handbrake, I think the height difference stems from it. If you use an abrasive (paste) with a nice polishing machine and then start polishing with polish, the problem in headlights will disappear. Car washes for 20 liras. [/ QUOTE]
08.05.2020 16:19 # 14
When we put two things in the trunk, it immediately falls down. Our cars are already more flexible than the front.
08.05.2020 16:19 # 15
AliOzagan
[QUOTE = Kemanyak] [QUOTE = AliÖzagan] I would appreciate if you share your result if you clean your headlight, but it needs cleaning in mine, but I am afraid I would make it worse & nbsp; [/ QUOTE]
:-))) Disassemble the headlights. If you throw a piece of cloth as much as a finger and shake it thoroughly with a nice cleaning detergent (it will not be abrasive), you will see the black work flowing through it with your eyes. & Nbsp; There was yellowing in my headlights but it was like a coal reservoir. It got its brightness on the first day officially.
08.05.2020 16:19 # 16
I Love My Pug
I think the user did not pull the handbrake because it is understood that the user seat and the back seat are full when looked carefully. There are people sitting inside and the brake lights are on, your car :) or what am I dreaming about?) = "0" alt = "Embarrassed" title = "Embarrassed" /> "Grin"
08.05.2020 16:19 # 17
I think if you touch the emery, if you touch it, it will not be nice. If it changes outside, it makes the most sense.
The second thing is the height difference of the vehicles; I have a few friends chopping the coil springs to lower the car, they chock the helix to raise it or take higher springs. You can adjust the height of the rear fender from the torsion setting. easy come.
08.05.2020 16:19 # 18
[QUOTE = 06ilhan06] If you clean your headlight in electricians and put it on new, I think that if you touch the sandpaper, you will lose its permeability, and the scratches on it will collect more dirt.It is most logical to change the exterior if it changes outside.
second event is the difference in the height of the vehicles; I have a few friends chock the helical springs to lower the car, take a chock to raise it or take higher springs. It is up to you to get higher. Easy to come. "title =" C o nfused "/>
08.05.2020 16:19 # 19
I am sorry, I will come to the same place because it is possible to raise and lower the vehicle with small movements in the suspension system. In vehicles with torsion, they can replace it with another part (coil springs) that it can play with in the system. Since I am sitting in a rural area, so that he does not hit the floor while going to the garden.
08.05.2020 16:19 # 20
Serdar
Kemanyak, AliÖzagan, and especially I Love My Pug :))) thank you for your praise :))) What I should know was the brake lights I was interested in. I looked at the brake light on the rear window, while I realized that there was no flash illusion on the rear window. heads even ears appear ahahahah
Page : / 2
