headlight settings
08.05.2020 18:55 # 1
xmen
My friends tool 307. Can I make these short and high beam settings myself. Can I fix their directions.?
08.05.2020 18:55 # 2
xmen
does anyone know Cry
08.05.2020 18:55 # 3
Alicilik
It is difficult to adjust manually. I tried like you, but there is no single setting. Finally I took it to the service.
While adjusting, they put a lens tool in front of it, and it becomes a coordinate plane. The headlight centerpiece line has to pass right in the middle of the coordinate plane, otherwise it is out of adjustment. It is impossible to set this as an eyeball.
08.05.2020 18:55 # 4
xmen
Thank you for your valuable comments, I will not be able to set it up in the service anymore.
08.05.2020 18:55 # 5
serdaralisan
my friend is in the closed garage, take the wall in front of him, adjust it accordingly, I am doing so, he keeps the setting at most a few miles of deviation
08.05.2020 18:55 # 6
xmen
[QUOTE = if you are serdarra] my friend is in the closed garage, take the wall in front of him, adjust it accordingly, I am doing the tuning keeps a few miles away
[/ QUOTE] I can actually try, but let's not disrupt the whole setting LOL
08.05.2020 18:55 # 7
herry
[QUOTE = xmen] [QUOTE = if you are serdarra] my friend in the closed garage, take the wall in front of him, adjust it accordingly, I do so the setting keeps up to a few miles of deviation
[/ QUOTE] I can actually try, but let's not disrupt the whole setting LOL [/ QUOTE]
Is it too tuned that your headlights, try it yourself, if you break the adjustment, you get a tie rod connector.
I give the detailed understanding link in order to help, examine will help.
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=22
08.05.2020 18:55 # 8
pusutr
How much do they charge in the service / industry for headlight adjustment?
08.05.2020 18:55 # 9
herry
How much do they charge in the service / industry for [QUOTE = pusutr] headlight adjustment?
I thought it would not exceed 20 TL, I gave 35 TL for the rot setting. The headlight adjustment felt easier with logic.
note: the price i said is for rotbalanci or auto industry. service gets a high price.
herry 2014-12-09 16:06:55
08.05.2020 18:55 # 10
serdaralisan
If you go to a normal electrician, it will take 20 tla, but the right headlight line will be slightly higher than the left headlight.
