headlight settings
08.05.2020 19:08 # 1
PARADOSK3327
My headlights seem to me a little burning, to whom should I show this? What is the subject of electrician or rot balancer? What kind of mechanic is there? There are headlight levels under the steering wheel.
08.05.2020 19:08 # 2
blntctn
Well I usually use it at 0, if it won't disturb the other and show me well, I think show it to an auto electrician
08.05.2020 19:08 # 3
talip206
Show your electrician your headlights.
it says in the user manual.
Depending on the load on your vehicle, the headlights
it is recommended to correct the beam setting.
0. 1 or 2 people in front.
-. 3 people.
1.5 people.
2.5 persons + maximum permissible load.
3. Drive + maximum permissible load.
The 0 position is the initial setting.
08.05.2020 19:08 # 4
PARADOSK3327
I just heard that it is according to kğ :)
08.05.2020 19:08 # 5
tolga.onal
According to the weight loaded on the vehicle, it is necessary to adjust the headlights accordingly as the back will approach the ground and rise to the front air. Of course, nobody struggles, including me, it always stops at 0. Sometimes when I go on a long journey, if there is a load, then I drop it down a bit.
08.05.2020 19:08 # 6
PARADOSK3327
actually you have to follow the rules
