headlight sensor malfunction
08.05.2020 16:13 # 1
fordtaunus
Friends & nbsp; while working normally & nbsp; headlamp sensors stopped working. Is there a place I need to check & nbsp;? I'm waiting for your help
08.05.2020 16:13 # 2
When the contact is open, long press on the button on the left arm, the active deactivated, I think the automatic part may have closed. I say check it out there
08.05.2020 16:13 # 3
droprain72
hello
if the battery terminal is removed, the headlight sensor will be canceled.
08.05.2020 16:13 # 4
metin
[QUOTE = droprain72] hello
if the battery terminal is removed, the headlight sensor will be canceled. DIV> & nbsp;
I want to fix it;
& nbsp;
the battery event you said is not certain. I have removed the battery many times, but my headlight sensors have not been canceled.
08.05.2020 16:13 # 5
___KxL___
It is interesting that if you do not disable it yourself, it will not work at all. I can say that there is a problem in the cable or something. >
08.05.2020 16:13 # 6
swat_407
a
08.05.2020 16:13 # 7
swat_407
hello,
& nbsp;
I had the same problem.
& nbsp;
battery was weak. When I started it again in the evening, the headlight sensor did not work and I used it manually. I renewed the battery, but I waited for it to recover, but it still hasn't. I made the suggestions above, but there were no changes.
& nbsp;
For your help and comments,
08.05.2020 16:13 # 8
toga406
My 406 bva headlight sensor turns on and off according to its head. so it doesn't work. Does anyone know why?
& nbsp;
and the light alert button are blinking. You will understand that it works according to its head in auto mode.
08.05.2020 16:13 # 9
toga406
It opens during the day. occasionally closes. may it be from what you call gel? I just bought the vehicle. I'm glad, but the sensor rearview mirror is broken. I wonder if that part was treated. Did the mirror part get damaged when it was removed and installed? what do you say.
08.05.2020 16:13 # 10
[QUOTE = toga406] opens during the day. occasionally closes. may it be from what you call gel? I just bought the vehicle. I'm glad, but the sensor rearview mirror is broken. I wonder if that part was treated. Did the mirror part get damaged when it was removed and installed? what do you say. [/ QUOTE]
Possible. There is no other possibility that will cause problems. There is a sensor and BSI headlights are on or off according to the data from that sensor. It usually results from the incompatibility or improper application of the jelly substance used in that area after replacing the ten glasses. Get well soon.
08.05.2020 16:13 # 11
Cmoss06
There may be a malfunction in the sensor sensor, if the front of the sensor is closed, the headlamp lights up and goes out even if it is on.
08.05.2020 16:13 # 12
toga406
thanks for the comments. Anyway, the rain sensor works, the other is constantly on, so it is insensitive to command:) "Ermm"
08.05.2020 16:13 # 13
toga406
Where do we get this gel? What is the fineness of removing the mirror in one?
If we stick to the glass, do we break the glass?
