Headlight sensor
20.04.2023 15:36 # 1
oates55
Friends, there is a small compartment near the windshield behind the trip computer. What is its exact name?
20.04.2023 15:47 # 2
oates55
If this part is called a headlight sensor, I can't find it online to buy it. The headlights are always on day and night.
21.04.2023 19:22 # 3
oates55
Friends, help me
28.04.2023 09:40 # 4
ersin61
It would be better to help you if you could write the make and model of your vehicle.
28.04.2023 15:58 # 5
oates55
Peugeot 307 2002 model
28.04.2023 16:43 # 6
oates55
[QUOTE=ersin61]It would be better to help you if you write the brand and model of your car[/QUOTE] Peugeot 307 2002 model
30.04.2023 01:46 # 7
mahmut alpay
Hello, the same problem as yours happened to me. I was told it was a COM 2000 problem. I bought the lamp and it turned out to be faulty. The problem was solved when I ordered the lamp arm from here and changed the lamp arm. If you come across a good electrician, the problem will most likely be solved by changing the lamp arm. The COM 2000 is an expensive part. I think it will be fixed by changing the lamp arm. Also, your signals may not be working properly, and even the horn and the lamp arm are reasonable in price. There can be two different ones. Mine is a 2006 model, I had the 206 film arm installed, and it has been working for 3 years, thankfully.
01.05.2023 08:09 # 8
oates55
Thank you, there seems to be no error with the signal lever and the COM. When I touch the part called the headlight sensor, it works sometimes, sometimes it doesn't work. Now it doesn't work at all. I can't find a new part. I think the fuse is blown, but I don't know where the fuse is.
20.05.2023 09:28 # 9
oates55
I can't find this part anywhere, which I think is faulty: https://lsgauto.bg/senzor-tablo-peugeot-307-sw-2002-2004-p181120n-182
01.06.2023 12:50 # 10
oates55
My problem is solved. When I turn on the ignition, the headlights come on automatically. It stays on when I start it. It goes off when I turn off the ignition. It turns out to be a very simple problem for my Peugeot 307 2002 model 1.6 xt. This problem is in the small compartment behind the information display. I can provide information for those who have the same problem and can't find a solution.
05.06.2023 18:49 # 11
imeral29
I have the same problem. The headlights are always on. Even during the day. Can you help?
