HEADLIGHT SELECTION
06.03.2022 01:13 # 1
bahadir63
Hello, I want to buy a new headlight set for my car, the gears of the headlights are gone (the master said so), so I couldn't adjust and I'm really having trouble on dark roads, also the right headlight is cracked and foggy. I want to buy something that will help me and make my vision quality, is it the headlight set we bought or the bulbs that are important?
The headlight set in the link looks really nice but I'll look into the standard ones if it won't improve my vision
06.03.2022 08:47 # 2
tsufrankwoli
Iranian headlights are poorly illuminated because of the flexi in the front, but if there is an old aftermarket on the vehicle, it won't make much difference. If there is an original, use ayfar or depot. The warehouse is the old original manufacturer. Currently, around 2 thousand TL, Ayfar domestic goods are sold around 1000 TL, the choice is up to you.
06.03.2022 17:52 # 3
bahadir63
Do you know about the following single lens model?
06.03.2022 21:57 # 4
Bi_ince
Either use a tank or Ayfar, if you want a very good vision, get a single lens and install a ds2 bulb in the headlight.
07.03.2022 11:28 # 5
Ayfar is very bad for my brother.
12.03.2022 01:18 # 6
bahadir63
Single-lens headlight set is 2300tl and after a while, the light emitted decreases a lot because the inside of the lenses darken, is there such a case? Are Lenses Expensive to Clean? Also, do the ds2 bulbs you recommend pass the inspection?
24.03.2022 11:10 # 7
heavyburak26
There is the "ertpeugeot" page on instagram. I bought the double lens one from there. it has a very nice look
