Headlight problem
08.05.2020 20:21 # 1
acabuco
Hello friends.
First of all, I wanted to get some information from you, since he told the electrician that he directly went to his job.
I have 206 model gasoline 206.
I can't burn the longs in my car, it expires after a certain period of time.
I cannot make a top selector, when it is done 2.3 times, the headlight arm loses its function, the light in the 4th-back pull does not light up, it stops.
Sometimes when I turn the headlight arm, it does not light up in a short time (this is very little) I have to rotate again
In general, I have a problem in my length, my selector, sometimes there are problems in short.
Do you think the event is in the headlight arm?
08.05.2020 20:21 # 2
talip206
99% coom2000 signal arm malfunction. Unfortunately it is a bit expensive, about 600. Because it's complete.
There are people who get it repaired and get an appointment. A little luck. If you find a good electrician, try to have it repaired if it gives confidence. talip206 2017-05-11 17:50:47
08.05.2020 20:21 # 3
The problem is most likely, as our friend said, we need to find a master who understands com2000 good auto electric electronics.
08.05.2020 20:21 # 4
acabuco
http://www.peugeotparca.com/peugeot-206-orjinal-far-sinyal-kolu-251310-urun1770.html ??
08.05.2020 20:21 # 5
acabuco
http://www.peugeotparca.com/peugeot-206-orjinal-far-sinyal-kolu-251310-urun1770.html ???
08.05.2020 20:21 # 6
talip206
The arms after the 2002 model are united. The arm you provided this link does not fit you. But to be sure, call that site and ask if your car is fit by giving the number of the chassis.
08.05.2020 20:21 # 7
acabuco
Thank you very much, sonar angel headlights how much do you know about this?
08.05.2020 20:21 # 8
acabuco
Anyone who says com2000 is hard to change says, do you have a master, have you ever changed pejo 206 com2000 before?
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
