Headlight Polishing
08.05.2020 16:36 # 1
kuantum
I sanded the headlight of my vehicle with water sandpaper on the internet, and applied scratch-removing cream. Unfortunately, it remained in the image. Though I still haven't applied polish, I applied the scratch remover cream recommended by the stand attendant at Koçtaş. Will it normalize when the polish is applied? Also, for how long do I have to apply the polish? or how much surface should I rub for scratch remover? I rubbed it for about 15 minutes. Is that all, is it normal?
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
Reviews
Reviews
Reviews
Reviews
< br>
< editID> quantum 2012-02-20 10:22:31
08.05.2020 16:36 # 2
gozem
Finish sandpaper should be 3000 number ..
How many numbers did you sand with ..?
08.05.2020 16:36 # 3
kuantum
I just bought polish and polished for 10 minutes. But there was not the slightest positive progress. By the way, I can say that the status of the headlight is worse than the one above. More blurry ..
08.05.2020 16:36 # 4
kuantum
There were 150 - 220 - 240 - 360 where I looked at the sandpaper, I bought them. I asked, there was no such thing as 1500-3000 or something. I said this might be a different numbering system. I thought it was a different dimension like meter-inch, kilometer-mile. because, for example, 360, the finest sandpaper I bought, was like plain paper. I can't imagine it could be thinner. Also, when I move my hand over the headlight right now, it has a smooth surface. there are only capillaries when you look very closely. is this normal?
08.05.2020 16:36 # 5
You used water when sanding, didn't you?
08.05.2020 16:36 # 6
gozem
My friend, you got the mistake, I started with 1200 while doing the headlight sandpaper (I even regretted using 1200) I finished with 2000-2500-3000, this is not the case with the numbered sanders you said. I wondered who was the master who said there was no 3000 number. :)
08.05.2020 16:36 # 7
kuantum
I asked both Koçtaş and the Practitioner. neither had either. and 360 was so thin that I couldn't even think of 1500. I don't think the problem is with sandpaper. but I will still look at it ..
and how long does the sanding and polishing time take separately normally for this job? for single headlight?
quantum 2012-02-20 14:58:40
08.05.2020 16:36 # 8
erkerd5429
my teacher it is not worth trying so much the previous week i made it like 30 lira cillop
08.05.2020 16:36 # 9
kuantum
[QUOTE = erkerd5429] my teacher is not worth trying so much I had it in the previous week it was like 30 lira cillop [/ QUOTE]
Where did you make
? I'm on the European side, I'll go and have it done.
08.05.2020 16:36 # 10
erkerd5429
No, you can not get it done, I am in Sakarya :)))) Do not give any more than 25 - 30 any painters.
08.05.2020 16:36 # 11
kaan__
There is not much you can do while the headlight has become this ...
so that your headlights can become old or bright & nbsp; I suggest you go to the end and ask them to clean the headlight ...
08.05.2020 16:36 # 12
Kemanyak
Get Meguiars PLASTX first. Then look for at least 2000 Grid sanders in painters. It would be better if you could find 2500. Then observe the condition of scratches by watering with 2000. It is very important that it is watery. And then apply PLASTX with the polishing machine and you will see that it is like glass. If you have a drill in your home, there are polisher sets that are compatible with the drill bit. You can also get results with them. & Nbsp;
08.05.2020 16:36 # 13
djchaos
How I do not understand the bodybuilder I do not understand, first sandpaper is made with 2000 sandpaper, then 3000 sandpaper is discarded as the last sandpaper. Normally, according to the condition of the headlight, you put the water in the 3000 sandpaper bucket and put the sand into the sandpaper. If you apply the cake polish by rubbing it, then you finish the polishing process with the machine beautifully.
08.05.2020 16:36 # 14
kudret_yildirim
my friend, you have used very thick sandpaper ... I wish you had searched the meanings of those numbers in the sandpaper first, the letter numbers that cope with the P letter code are the class code and standard sales are produced up to the P2500 class code. Abrasion feature is specified with this code. As the number grows, the mass of the abrasive molecule becomes smaller. There are 1500 abrasive molecules per cm. They are also classified as water sander and dry sander. You should definitely have used water sander and you should support water abrasion. I wish you had a little research and try it out.
08.05.2020 16:36 # 15
kuantum
Guys MALESEF I used wrong sanding numbers. I used very thick sandpaper :( Now, my question is, after this hour, will I damage the headlight if I sand the headlight again with the correct numbered sanders and try it again? >?
I would be glad if you could help.
08.05.2020 16:36 # 16
demiral_o
Hi, I wonder where you cleansed in Sakarya, your headlights, I am staying in Sakarya.
