headlight mist removal
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 19:00 # 1
Adem Kurtuldu
I hope that I will take steam with a little water in my 206 vehicle's headlight and fog, since I have a little water in it, I hope that I will take steam with the heat gun used by the accessories, how do I apply it more easily? I a.kurtul 2015-01-15 19:10:51
08.05.2020 19:00 # 2
Adem Kurtuldu
No one's knowledge? ????
08.05.2020 19:00 # 3
samet206
If the headlight does not crack, it does not steam, the headlight does not steam, but even if it is done in cold weather, the bulbs have to disappear from the heat of the headlamps. In order to remove the current steam, I suggest you remove one of the bulbs and you can get the steam with a device that blows warm or cold air from that hole. You do not need a heat gun for this job.
08.05.2020 19:00 # 4
okaNStarss
Do not give too hot air and hold it away, or the glass may remain in your hand
08.05.2020 19:00 # 5
Adem Kurtuldu
Well, it is not coming anyway, when it gets better with this, when the weather gets better, insert glass directly and wipe it clean
