headlight dimming
08.05.2020 14:17 # 1
Melih
Hi friends, I want to make a difference for 1999 model 206.
08.05.2020 14:17 # 2
berko
If the headlights are frosted glass, I don't think it will make any difference. Buy transparent headlights first. Buy a pair of warehouse brand sub-industry headlights for the money you will give out of headlight dimming. they're easy to open, you can blackout yourself.
08.05.2020 14:17 # 3
Melih
yes, thanks for your advice on the frosted glass model, as you said, the most logical thing to do is I would also clean the headlights.
08.05.2020 14:17 # 4
Melih
do you know a place selling deo brand transparent headlights on the internet
08.05.2020 14:17 # 5
berko
I know it sells spare parts sites, but it's easy on industry spare parts.
08.05.2020 14:17 # 6
sempatik87
they do the dimming of the headlights for 20 30 lira in Istanbul but unfortunately you are in the imitt :)
08.05.2020 14:17 # 7
[QUOTE = sempatik87] they make the dimming of 20 30 lira in Istanbul but unfortunately you are in the district :) [/ QUOTE]
where are they doing 20-30 pounds
08.05.2020 14:17 # 8
SUPERMAN
yes where are they doing 20 30 lira
08.05.2020 14:17 # 9
Gülme Hello .... If you want to darken the headlights, there is no recycling in mica glasses. Fog method is being used on glass headlights ... but I don't know in Izmir .. ****** does this job
Edit EmRaH: It would be better if you give your personal addresses and numbers to the internet site.
emrah 2010-08-24 17:01:57
08.05.2020 14:17 # 10
H-a-d-i
[QUOTE = f tuning] Gülme Hello .... If you want to darken the headlights, there is no recycling in mica glasses. Fog method is being used on glass headlights ... but I don't know in Izmir .. ****** does this job [/ QUOTE]
are you the owner of this company? emrah 2010-08-24 17:02:17
08.05.2020 14:17 # 11
alpbeyazi
[QUOTE = Come on] [QUOTE = f tuning] Gülme Hello .... If you want to darken the headlights, there is no recycling in mica glasses. Fog method is being used on glass headlights ... but I don't know in Izmir .. ****** does this job [/ QUOTE]
are you the owner of this company? [/ QUOTE]
Come on, logical approach, brother Thumbs Up
08.05.2020 14:17 # 12
BuRCaK
"f tuning" is not clear to us? Sleepy
08.05.2020 14:17 # 13
metin
I was going to open a new topic, but I looked at the subject, I said I'll ghost him
I was thinking about dimming the headlight, then I would like to get your comments on how I would make the body color instead of black if I turn on the headlights.
I also appreciate where I can get water sandpaper, plastic liner and paint.
08.05.2020 14:17 # 14
yeditepely
[QUOTE = text]
let me continue on the subject that is glowing :)) how do you open my friend, give me an idea or give me an idea.
water-sanding primer is sold in hardware store. yeditepely 2011-07-01 12:09:00
08.05.2020 14:17 # 15
metin
Since it is a little bit secluded here, it is not happening here. I went to the practice yesterday, I couldn't find it.
I have the job of making the body color inside the headlight like this 207 in my head.
08.05.2020 14:17 # 16
yeditepely
How is this red?
08.05.2020 14:17 # 17
metin
The silicon in the glass softens after it is heated a little in the heat gun or oven, and then it opens easily, I am in the research.
08.05.2020 14:17 # 18
yeditepely
After softening the headlight plastic with silicons and losing its shape: ((
08.05.2020 14:17 # 19
Muhammet CAKIR
:) my subject is text this is the job :)) watery sanding primer and after throwing liner does not need to be excited, do not need to sand it neatly, get a good quality paint, do not look back at all. Put it in front of the stove, then insert the screwdriver between the headlight and headlight glass and it will hurt. If it pushes a lot more, put a little more down on the stove, press something else when you open it, and you will see the next ones come out like this :)
08.05.2020 14:17 # 20
Muhammet CAKIR
After the [QUOTE = yeditepely] silicones, the headlight softens and loses its shape in the plastic: (The correct heat guns that you call ((/ / QUOTE) are inconvenient because of this reason) It is more logical and safe to use the electric stove.
Page : / 2
