Headlight cleaning or sub-industry headlight
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:54 # 1
Bavik
My friends inside the front headlights of my car are quite dark, at the same time, there are cracks on the upper nails, I have to make my headlight cleaning, or if I buy and install the side industry headlights, I couldn't decide directly, the side of the sub-industry headlight comes to 240 lira, the headlight cleaning couple is around 150 i 406 tools & nbsp;
08.05.2020 16:54 # 2
I do not recommend sub-industry. Don't you have a chance to get out?
08.05.2020 16:54 # 3
Bavik
If you want the same money with the original zero, you can find 200 lira, you can find zero original i from 230.
08.05.2020 16:54 # 4
[QUOTE = Bavik] If you want the same money as the original zero, you can find 200 lira for the original zero from 230. Are you sure the original is 240 pounds?
08.05.2020 16:54 # 5
Bavik
In the sub-industry, the couple comes to 240, the original one is 230, the couple is 460, but then I mean the price & nbsp;
08.05.2020 16:54 # 6
[QUOTE = Bavik] in the sub-industry, the pair comes to 240, the original one is 230, the couple is 460, but then I mean the price & nbsp; [/ QUOTE]
I am personally in favor of taking the original. Anyway, you can't wear a single color difference. It looks like getting out in the most beautiful team.
08.05.2020 16:54 # 7
Serkan
I cleaned it yesterday, I gave 100 TL to the couple, it was not like zero, but it is considered close to zero, they cleaned inside and outside.
08.05.2020 16:54 # 8
Bavik
I think I need to do some market research, but it seems logical to get out & nbsp;
08.05.2020 16:54 # 9
serkanadu
I could not decide on the same subject. I asked today & nbsp; to industry. As you said, the sub-industry pair is 240 TL ... cleaning 150 TL ... I don't know what to do.
08.05.2020 16:54 # 10
individual
I would definitely not recommend sub-industry headlight.
I bought a warehouse brand. Even the way was not correct.
There were also paint errors in the reflector.
08.05.2020 16:54 # 11
erenuluoz
bavik brother greetings, if you give the last 8 digits of the vehicle's serial number, i can get you a nice price for zero. I agree with friends too, do not buy sub-industry.
08.05.2020 16:54 # 12
atakanka
Is this headlight cleaning event done at the stop lamps?
08.05.2020 16:54 # 13
yenice
I checked the headlights too and I couldn't see a brand. Inside the hood, it says HCR PL 05450. & nbsp; Are these original headlights?
08.05.2020 16:54 # 14
serkanadu
[QUOTE = individual] I would definitely not recommend the sub-industry headlight.
There were also paint errors in the reflector. [/ QUOTE]
Yesterday I asked a master in the industry. The man is doing headlight cleaning. He said that I would definitely not recommend the sub-industry headlight. The places to be screwed could also be incompatible. Then headlight clearing forever ... 150 TL
08.05.2020 16:54 # 15
yenice
If I ask friends, can people with the original headlight look at the codes on the inside of the headlight? I am writing HCR PL 05450. There are lines parallel to right to left over the headlight. is this headlight original?
08.05.2020 16:54 # 16
goktug
[QUOTE = Serco05] I gave 100 TL to yesterday, I did not like zero, but it is considered as close to zero, they cleaned it inside too [/ QUOTE] Where did
have your sister address & nbsp;? Does it make us 100 too?
08.05.2020 16:54 # 17
herry
Be careful while friends clean the headlight, they put my headlight on the vehicle, poured the cleaning drug into the car, shake it, as the result is old, the bright paint inside is removed in some places. I had to get the headlights and darken it, I had to pay 200 TL in time.
08.05.2020 16:54 # 18
Serkan
[QUOTE = göktuğ] [QUOTE = Serco05] Yesterday I gave the couple 100 rubles, I did not give it like zero, but it is considered close to zero, they cleaned it inside too [/ QUOTE]
where did you give it sister address & nbsp;? Does it make us 100 too?
08.05.2020 16:54 # 19
SZKR
Sub-industry headlight is definitely not my advice. We wore it to 307 because the leg of the original was broken, but it will definitely have an illusion that will bother you. It makes a lot of difference with the original.
08.05.2020 16:54 # 20
Serkan
[QUOTE = 307 bursa] headlight cleaning job is not healthy friends and I tried to see it for 1 month but then it is getting old again, headlights are in vain, do not waste your money. . & lt; div id = "isChromeWebToolbarDiv" style = "display: none" & gt;
In my opinion, do not clear it, you will see that your money is going to waste after 2 months.
Page : / 2
