Headlight Bulb Advice
08.05.2020 21:12 # 1
x571
I need a pair of H7 12V 55W headlight bulbs. Should I buy standard osram for 10 liras? Would you recommend another brand model? Is it true that I say 110% - 130% more light, I illuminate 50 meters? shaking?
I will also need a pair of bottomless parking bulbs. reading the writings on it is like edict but
There are p12v written below, e1 next to e1 in the box, v5 w or 15w which I cannot read. I wonder what could this be? Would it be a problem if I put 15 w in a 5w place :)
expectations: properly illuminate, no problem in rainy, foggy weather, do not explode for a long time. So when you wear it, let's go for 5 years.
08.05.2020 21:12 # 2
maximusti
Osram Nightbreaker or Navra 85w
These two are not very miserable when it comes to lighting.
parking bulbs are also called T10.
08.05.2020 21:12 # 3
x571
[QUOTE = I maximus]
Night breakers are said to explode in 1 year. Have you ever used it? What is the situation
08.05.2020 21:12 # 4
maximusti
[QUOTE = x571] [QUOTE = I maximus]
I used it in my falcon 7 8 years ago, I did not have any problems for 2 2,5 years, then I sold the car.
08.05.2020 21:12 # 5
Karacocuk24
[QUOTE = x571]
You can buy Philips osram and bosh brand, narvada business will see how long it will go or not.
08.05.2020 21:12 # 6
x571
[QUOTE = Karacocuk24] [QUOTE = x571]
Thanks for your interest. I bought a pair of Osram 12v 55w. I bought a T10 bottomless bulb in a pair of 11 lira each, 3 lira. I rarely drive at night. The long way I drive is rain fog. Expensive plans are usually white. I did not trust the whites, I did not show in the rain or read the articles.
08.05.2020 21:12 # 7
tsufrankwoli
You bought it but if you want to buy it again or if it helps someone else, general electrik is good. Lights up to 30% white. The most important factor with its lifetime is that the headlights are off when starting the vehicle.
