Headlight arm
08.05.2020 17:35 # 1
sulocan_5
I have a 2004 Peugeot 206 XT vehicle .The signals of the headlights are not working when the headlights are turned on. According to the electrician, the complete arm had to be changed. The code was 6242c2. Doesn't it repair? / p>
08.05.2020 17:35 # 2
I don't think it's from the arm. Very likely the chassis connection point is corroded or broken. Take a look at the back of the headlight and see if you can see the cables attached to the body with a nut. If you see, do a little maintenance and try it. Sometimes this event can also happen when a double-flamed lamp is attached to the signal lamp. Have there been any lamp changes lately?
08.05.2020 17:35 # 3
Alicilik
[QUOTE = sulocan_5]
I have a 2004 Peugeot 206 XT vehicle. When the headlights are on, the signals don't work. According to the electrician, the complete arm had to be changed. The code was 6242c2. Doesn't it have repairs? Because they gave a very low price. >
needs to be removed and examined. Nobody has to deal with it, even removing the com2000 is a problem.
You can get more suitable by means of publishers or sponsor Şahin Hawks. it will be healthier. Reviews
08.05.2020 17:35 # 4
rolandgarros
In fact, every time I wear a contact, it signals either right or left. LOL
08.05.2020 17:35 # 5
sulocan_5
Thanks to a familiar electrician, he did it ... Thank goodness he works.
08.05.2020 17:35 # 6
emre_akdag
Get well soon :)
08.05.2020 17:35 # 7
rolandgarros
Even when the right signal of my arm is going very sensitive, sometimes it starts to signal itself, does it make it from the arm? or is it an electronic problem?
