Headlight and Signal Problem
08.05.2020 21:23 # 1
bilisimci01
Hello 2011 on my 206 model 1.4 car
Automatic headlights turn on when I turn on the park Headlights When the lights come on Most of the time it does not work.
08.05.2020 21:23 # 2
omerb
Hello, I had the same problem. Only the vehicle has a headlight sensor. The button that activates the headlamp sensor at the signal lever end is pressed too hard. The arm got in too much. I turned the headlight switch and pulled it back slightly, the problem went away. Try it. Because there are platinum legs inside. They are in contact with each other.
Also, the horn was not playing when the headlight was on. It was all because of this simple malfunction.
08.05.2020 21:23 # 3
I think the connections may have been wrong after inserting the american park. didn't it work before him?
08.05.2020 21:23 # 4
bilisimci01
[QUOTE = sonerkyl] I think the connections may have been made incorrectly after inserting the american park. it didn't work before it [/ QUOTE]
malefes american park was not working when i don't know before, frankly i mean i had it on when i bought it com2000 it is a bit costly to replace it, i guess it might be a problem in the connections
08.05.2020 21:23 # 5
bilisimci01
[QUOTE = omerb] hello I had the same problem. Only the vehicle has a headlight sensor. The button that activates the headlamp sensor at the signal lever end is pressed too hard. The arm got in too much. I turned the headlight switch and pulled it back slightly, the problem went away. Try it. Because there are platinum legs inside. They are in contact with each other.
horn it doesn't work in me LOL the problem is the same i will try right away
08.05.2020 21:23 # 6
GokhaN
it looks like it's time to get a new com 20000
08.05.2020 21:23 # 7
GokhaN
[QUOTE = GökhaN] it looks like it's time to get a new com 2000 [/ QUOTE]
08.05.2020 21:23 # 8
omerb
we are waiting :)
18.07.2021 14:31 # 9
omersari
hello
206+ You didn't mention that when you close the parks you live in your car, the headlights come on automatically, but you didn't mention about it. You followed the path, what was the result, can you share?
