Headlight & Stop Cleaning
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:45 # 1
fatihgg
My friends angel headlights and the stops are over-dusty. Can you be solved with things like spray etc ... without turning them on? In the industry, I ask the guys, they want the new headlight stop money to clean & clean & nbsp; ahh if they do it. i'm waiting for your help.
08.05.2020 16:45 # 2
canziy
we have the same problem with me, I have left headlight darker than the other, we are waiting for cvp from friends who have knowledge about this subject or who know how to make it affordable price
08.05.2020 16:45 # 3
ufuk91
I do not think it is possible to clean without opening, but they should not want as much as you mentioned. If you have a skill, research the opening patterns and do it yourself.
08.05.2020 16:45 # 4
fatihgg
What if I was going to open ourselves, I am telling you for me 6-7 years.
08.05.2020 16:45 # 5
tigerland
if you only have dust. Remove the headlamp, then remove the long and short bulbs, and hold the 3 screws in their slot. do not lose the screws :)
then, with the air gun in the industry, keep some air away from the dust, the dust will be removed, then pull it with a nice broom.
This is the method I can think of .. at least you can clean without opening the headlight
08.05.2020 16:45 # 6
fatihgg
it does not happen compressor has been tried, it takes the upper part in the baseboard, as if the blackness is no longer stuck in the substrate, it says husran.seytan.
08.05.2020 16:45 # 7
YUNNES37
http://www.meguiars.com.tr/ product_info.php? 46_6 & amp; products_id = 147
there is a product like this, but it is a little expensive
I have seen that I have used it only before
08.05.2020 16:45 # 8
fatihgg
Good quality material, but is there anybody who applies it?
08.05.2020 16:45 # 9
criminal80
it is not cleaned without opening it. you don't mess with it. opening trouble 1 separate trouble closing separate 1 trouble. They remove and clean the headlights up to 80 TL. I had the 4-year-old angel headlights removed and the leds of the rings changed. super craftsmanship. who thinks I got the new zero angel headlight. the result is so perfect
08.05.2020 16:45 # 10
fatihgg
Where did you get it done, do not change the leds or something.
08.05.2020 16:45 # 11
efe1988
remove the headlight & nbsp; Fill the water so that it does not get pressurized from the bulb hole, shake it, then filter it in reverse and dry it in the sun. I tried it. T o ngue "/>
08.05.2020 16:45 # 12
fatihgg
I guess if we do this in 307, the car will get crazy: D
& nbsp;
criminal80 where did you get that work if we find it super.
