Headlamps self-extinguishing
08.05.2020 20:21 # 1
Elmetin
While the vehicle was in motion, all headlights suddenly went out and the tape worked. When I opened the door again, the tape stopped working for about 5 seconds. I would appreciate it if anyone has an idea why it might be due.
08.05.2020 20:21 # 2
Furkan979
I think the battery may be running out.
08.05.2020 20:21 # 3
keaven
I think it's not a coincidence that after the cleaning, there might be some contactlessness in the sensor in the mirror.
I have a question, to activate the headlight sensor, press and hold the signal lever (only if the battery light is on contact).
08.05.2020 20:21 # 4
Have your battery checked first, these warnings are usually given because the battery is running low. If you look at the production date of the battery, it is already clear, isn't it? If your battery is new, remove the motor fuse board and check for oxidation. Also, have the vehicle's electrical chassis connections checked. sonerkyl 2017-05-22 08:59:11
08.05.2020 20:21 # 5
gurkan.gokdeniz
Hodja, I had the same problem, the battery's polar heads were oxidized after cleaning with hot water.
