Headlamp sensor for 206 - 206+ (plus) (night)
08.05.2020 17:02 # 1
Alicilik
Hello friends,
It is a curiosity I have asked for a headlight sensor. I want to find the part and apply it to my car, but what kind of parts do I need to have connections with? I am waiting for help.
08.05.2020 17:02 # 2
spearo
success in the new episode and excitement ali;)
08.05.2020 17:02 # 3
Alicilik
[QUOTE = spearo] new episodes and success in excitement; "title =" LOL "/>
08.05.2020 17:02 # 4
spearo
I'm also entering the torpedo lamp project:) & nbsp;
08.05.2020 17:02 # 5
fexzi
I know that I need to connect the terminals & nbsp; + and - from the fuse panel in combination with the fuse box for activation of the photocell in the sensor.
08.05.2020 17:02 # 6
Can I get the RPO number of the vehicle?
http://forum.peugeotturkey.com/forum_posts.asp?TID=17696&PID=304555&title=pp2000-iin-obd-ii-cable-yardm#304555 < br>
08.05.2020 17:02 # 7
KenBlockJR
I think the rain sensor is more necessary than the headlight sensor. I have both but I don't use the headlight sensor
08.05.2020 17:02 # 8
Alicilik
[QUOTE = koliva] Can I get the RPO number of your vehicle?
1239388 brother
08.05.2020 17:02 # 9
[QUOTE = Buyer]
1239388 brother
Okay. So, Member 1. Do you know the engine of your car? Which of the below? If you can send your chassis number, I can look at it.
a) Turbo Diesel DV4C,
b) DV4TD Turbo Diesel
2. Does your vehicle have an EPS?
3. Does your vehicle have ABS?
These questions may not be related to the headlight sensor, but I want it to be solid. Otherwise, I am sure whether or not ABS will be the same.
Note: I'm a little busy these days so I can't look at the forum as much as before. Do not mind my fault.
08.05.2020 17:02 # 10
spearo
vehicle engine dv4c & nbsp;
08.05.2020 17:02 # 11
[QUOTE = spearo] vehicle engine dv4c & nbsp; [/ QUOTE]
So assuming the following configurations (if not, please let me know)
There is a point here. If I choose the wiper part from the sky, it asks me if I want rain or sensorless. If I choose the sensor, the diagram below is as follows. The place where I bought red is showing the rain sensor and its connections. However, when I applied the same thing to the headlights, the sensor did not ask me. Still, the sema is the 2nd sema below. Again, I marked the rain sensor there with red. I couldn't examine in great detail, it takes quite a while to find and extract these diagrams. If one of the figures in the second schema shows the headlight sensor, that scheme can be used. Something like that came to my mind. This rain sensor and headlight sensor are in the same unit in 307s. If it is at 206 +, maybe the connections of the rain sensor below include the headlight sensor. If you have information about how many ports are coming out from the sensor, maybe I can give you some more ideas.
Rain wipers with sensor:
Headlights:
koliva 2012-09-13 08:14:06
08.05.2020 17:02 # 12
Alicilik
Thank you very much Aykut brother.
As Cenker brother said, there is no esp dv4c
abs
I apologize for you. As far as I understand it is not what I can do. You have to do it with an expert. Finding the priority sensor.
08.05.2020 17:02 # 13
[QUOTE = Alicilik] Aykut brother thank you very much.
abs
I apologize for you. As far as I understand it is not what I can do. You have to do it with an expert. Priority is finding the sensor.
If you want the rain sensor, let's do it immediately "Smile"
koliva 2012-09-13 15:00:55
08.05.2020 17:02 # 14
spearo
okay if you find the sensor with this scheme, you will pull the installation and activate it from pp2000.
08.05.2020 17:02 # 15
spearo
206 have 4 legs in the cellar
08.05.2020 17:02 # 16
spearo
our vehicle config is the right tool dv4c bvm5 enthusiast absli esp you
08.05.2020 17:02 # 17
Detailed diagram for the rain sensor:
There are 4 connection points.
Leg 1 through the EX16 port to the F14 fuse,
Leg 2 through the E901B port to the 40th leg of BSI,
3-leg leg via the EM20A port to ground 20,
4-leg leg through the E901A port to BSI leg 38,
must be connected.
08.05.2020 17:02 # 18
blinddark
my vehicle 2003 307 1.4 hdi xr can we install headlight sensor and rain sensor on this bidet do you know what their prices are
08.05.2020 17:02 # 19
Alicilik
Aykut brother, I'm going to ask you one more thing, but I'm sorry.
Headlights are getting electricity from BSi instead of direct com2000, right? BSi sends current to the headlights with command from com2000?
If so, how can I find the outputs of the headlights (front dipped beam-parking lamp-signal-fog)? You know the tape, a chassis goes 2 currents, one goes directly from the battery and the other one, can we find out where this contact, which we call Contact, comes from BSi? I think I have been too "Embarrassed"
08.05.2020 17:02 # 20
Gladly. Since the answers are long, I will reply in different messages.
[QUOTE]
If so, how can I find the outputs of the headlamps (front dipped beam-parking lamp-signal-fog)?
Remove the socket on the left or right headlight. Then you light up any headlight lamps, for example short headlights. You confirm that the lamp is on when you do not remove the socket. Then you connect the black end of the measuring instrument to the chassis, and the other end into the socket one by one. Whichever voltage you get, it is short fard "Wink"
Page : / 2
