HDI engine snoring (RESOLVED)
08.05.2020 16:18 # 1
06OzGuR06
& nbsp; friends have been in my car for a while in the form of snoring.
This sound occurred after replacing the air filter.
2. When I shift into gear and press the throttle, when the engine is overturning, the sound of Hortt is heard at 1500 rpm. It is vibrating.
Anything happening to you? Has the idea of a solution. Thanks ... "Laugh"
< edited> 06ÖzGüR06 2011-12-05 00:59:18
08.05.2020 16:18 # 2
Engin Tepe
I've never had one.
08.05.2020 16:18 # 3
It happened to me at 3071.4hdi, I removed the air filter box and then attached it to the plastic suction pipe that came to the front from the back of the box, I did not attach the rear connection properly, it sounded very sweet.
08.05.2020 16:18 # 4
06OzGuR06
Thank you friends
I think this problem is caused by the vibration of the plastic suction tube.
because there is absolutely no leakage or gap in the filter box.
(not too exaggerated sound either actually but my ear
I am only because it is constantly in the engine.) "Grin"
My solver, I hope this job ...
08.05.2020 16:18 # 5
06OzGuR06
The problem is solved. The subject can be deleted.
The sound was caused by the vibration of the lower crankcase casing. I did.
06ÖZGüR06 2011-12-05 00:59:46
08.05.2020 16:18 # 6
rifatseker
:))) This crankcase cover is really a very annoying event .. :) While my crankcase cover was plastic, there was no problem. Then I got the iron one and it was 1500 cycles and then it sounded like sound from the front console. Then I came to my mind when I changed the crankcase. When he went and tightened his screws like a man, the voice ceased. :))
