Have you ever had such a problem?
08.05.2020 15:04 # 1
bydennis
friends I have a strange problem in my car, I think it is because my car is grasping from a very low angle. when I am not working, I am running after a short period of gears, I am recovering, have you ever encountered a problem ???
I had the car running in gear, and after experiencing the same problem, the car moved while my foot was in clutch, it got up on its own.
viteste me?
clutch
08.05.2020 15:04 # 2
ali oncu
I think your trouble is in the clutch, brother, you have to look for the clutch first, then the gear.
08.05.2020 15:04 # 3
metin
the problem is in the clutch.
08.05.2020 15:04 # 4
bydennis
If I show it to the mechanic
08.05.2020 15:04 # 5
Muhammet CAKIR
Of course moments
08.05.2020 15:04 # 6
se®k@n
Take a look at the clutch adjustment.
08.05.2020 15:04 # 7
gozem
well they adjust it, if you want you can have it grasp a little higher from above.
08.05.2020 15:04 # 8
Muhammet CAKIR
[QUOTE = my eye] well you can set it up, if you want, you can set it to grip a little more from above. There is no overnight :)
08.05.2020 15:04 # 9
gozem
I get it, some money is stuck there ..: D
08.05.2020 15:04 # 10
bydennis
on the road, not on the road, not on the road, but when I'm on the road, I'm going to throw the problem from 3 to 4.
08.05.2020 15:04 # 11
d3Li
printing can be on pad
08.05.2020 15:04 # 12
some of the adjustment wires have adjustment mechanism, some do not. You have to look at it at 106. If there is, it is necessary to make sure that the clutch point is raised and the degradation separates it. The problem comes as if it was a strong possibility. it may be necessary to look at the suspect if the drive does not correct ...
08.05.2020 15:04 # 13
turgay_87
slm this gear issue was also in my car 106 gti same as your friend told me, i left the car to the master i bought it from the master for the rot the car was like that the bode steering box was inserted and a record was made, i say the master said it was like this but the master said i didn't do it I wonder what could have happened if the friend who had this problem had it made?
08.05.2020 15:04 # 14
turgay_87
slm
08.05.2020 15:04 # 15
turgay_87
slm friends, this friend is not in gear, kunus was in my vehicle, as he told me, as if he made me have a friend with this problem, he made a problem
