HARDENING
08.05.2020 18:30 # 1
akantek
Hello friends
The steering got heavier when nothing was in the middle, and the brake got stiff.
I tried the brake, there is nothing to hold and even ABS is engaged when it is hung. But when you press the pedal, the pedal does not descend 1-2 cm. Confused
it was as if the hydraulic was disabled at the wheel. I looked at both the steering and brake fluids, there is no reduction. Some friends know that there is a humming noise when turning the steering wheel to the end (I think there is something like the steering engine in previous issues), there is no abnormality in it, sound or something.
I couldn't understand why, is there anybody with this kind of knowledge? Cry
by the way my car is 2001 model 206 xt 1.6
akantek 2014-05-01 17:39:33
08.05.2020 18:30 # 2
okankrgz
There may be a problem in the relays that manage the steering pump and abs. Have the electrician check it ... there are coals in the steering pump (if it is electric).
08.05.2020 18:30 # 3
akantek
[QUOTE = okankrgz] Steering pump and relays governing the abs may have some trouble, have the electrician check it ... there are coals inside the steering pump (if it is electric).
he does it only occasionally, but his waist improves after a while
08.05.2020 18:30 # 4
pusutr
Have you checked the crank pulley, the belt?
08.05.2020 18:30 # 5
akantek
No I have never thought of looking at the belt pulley part. but if there is a problem with the belt, will not the traction fall?
08.05.2020 18:30 # 6
VLKNYKSLN
Repentance repentance when hardening: D
08.05.2020 18:30 # 7
akantek
[QUOTE = VLKNYKSLN] repentance repetition when typing: D [/ QUOTE]
thank god no problem bro :)
08.05.2020 18:30 # 8
mustafa_nalcacioglu
Check the V-belt when it is ole.If the car lights up, it is possible that the problem may be caused by the belt. the mustafa_nalcaciogl 2014-05-03 18:51:45
08.05.2020 18:30 # 9
blue42
Could hydraulic oil be reduced?
08.05.2020 18:30 # 10
akantek
No bro, I looked at the strap, no problem. There is no glitch in the charging light, however. hydraulic oil is also ok. even hydraulic oil is a little too much. overflowed from the cover. Could the oil flowing occasionally come into contact with the belt? I did not find any trace of oil on the strap though.
08.05.2020 18:30 # 11
EmSul
Peugeot does this, it gets so bad that it gets better over time.
08.05.2020 18:30 # 12
akantek
then you need to get your heart with a cake polish or full tank every now and then LOL
08.05.2020 18:30 # 13
muku
[QUOTE = VLKNYKSLN] repentance repetition when typing: D [/ QUOTE] LOLLOL
08.05.2020 18:30 # 14
rifatseker
How many men think like me :) :) :)
08.05.2020 18:30 # 15
serkomser
Honda had been in my car, I had put more oil than needed, and the brakes of the car were stuck. I think try to have an oil change.
08.05.2020 18:30 # 16
akantek
[QUOTE = eurest] Honda had been in my car, I had put more oil than required, the vehicle's brakes remained tight. I think try to have an oil change. [/ QUOTE]
can be worth trying. Thumbs Up
