hard clutch problem
08.05.2020 17:17 # 1
resul0671
Hi guys,
In 2005 model 307 im clutch is harder than usual. It works as if it has two stages in cold weather. When it comes to the middle of it, it looks like it gets stuck somewhere.
& nbsp;
pressure pad looks good. my vehicle is at 78000. Is aceba printing from pads??
I would be happy if you help ....
08.05.2020 17:17 # 2
ondercan
Hello there. On top of the gearbox, I suggest that you keep an air from the piece called the fork, which the rope rides. Only two people will be required. One person will remain pressed to the clutch. Otherwise, the fork will hold the air inside. Be careful. The dust of the lining hardens the fork that the rope rides on and off.
08.05.2020 17:17 # 3
resul0671
thanks. I will try and report the result
08.05.2020 17:17 # 4
istanbullu_3886
the ball presser feet of the print may be worn down I think check them later
