HARARET NEEDLE
08.05.2020 21:05 # 1
27BEN80
Is the temperature in the 80s and 85s in the summer time normal in the 70s and 65s in the winter?
08.05.2020 21:05 # 2
Not normal brother, thermostat - temperature sensor or the most beautiful vehicle with defective indicator, connect to the computer and look at the temperature of the radiator water.
08.05.2020 21:05 # 3
talip206
[QUOTE = 27BEN80] Is the temperature in the 80-85s in summer normal or in the 70-65s in the winter? [/ QUOTE]
The distance you go depends on situations such as traffic and uphill.
For example, 8 km between home and workplace. Since there is traffic in the morning, when I get to work, the temperature is between 90 and 100. My average arrival time is 20-25 minutes.
I take the same way in 10-12 minutes without traffic after work. When I come home, the heat is around 80.
If you write the conditions such as road, time and traffic in one go, it can be answered more clearly.
If it stays at the same setting even for a long time, it does not go up, as Soner said, thermostat etc. there may be a malfunction.
talip206 2018-12-04 21:16:19
08.05.2020 21:05 # 4
27BEN80
Thank you for the cavps, I guess there was a problem in the display, I guess it must be repeated again, as I said, I have to try a little distance.
