HARARET MAKES CEILING FROM EMERGENCY AID FRIENDS
08.05.2020 18:46 # 1
gokhan.kavutcu
FROM THE ENGINE WHEN GOING ON THE ROAD, THE MOTOR TAKES UP TO 10 MINUTES AFTER HEATING 10 10 SECONS LATER TAKES IT TO OLD AND AFTER THAT IT CONTINUES TO BE CONTINUOUSLY CONTINUOUS.
08.05.2020 18:46 # 2
TaZ
it will probably be from the client, because when the socket is removed, the temperature seems to be the end, stop will flash, it will help if you show it to the nearest good electrician.
08.05.2020 18:46 # 3
volkanC2
I have the same problem with my handset, I changed my soul, I did not change the socket, it is still the same.
08.05.2020 18:46 # 4
volkanC2
the problem disappears when I operate the air conditioner, the fan of the air conditioner and radiator is the same single fan, so I recommend it from the obstruction of the radiator with the recommendation of a few people
08.05.2020 18:46 # 5
ertanakar
Replace the fan role..the front grill has a mobile phone-sized cover.
08.05.2020 18:46 # 6
koray
it happened to me. I changed the fan shield. problem crashed
08.05.2020 18:46 # 7
Foxfire
I think the fan relay is the definitive solution because I changed it in three times.
08.05.2020 18:46 # 8
koray
I had two roles at the same time. may also be roles.
08.05.2020 18:46 # 9
eraynaim
Friends, I have such a problem. But when the vehicle reaches the speed between 130-150 and not immediately, the temperature rises to the right, stop right, it improves.
In addition, when the engine moves while it is cold, it pretends that it is cutting diesel oil and continues again.
08.05.2020 18:46 # 10
koray
the same was happening when I landed from a high area to a low area in my vehicle. When the sudden movement fell, the stop lamp was suddenly on. the movement was making the ceiling. when I took out the battery cap and put it back on it it was getting better. I changed the role and the manager improved.
08.05.2020 18:46 # 11
eraynaim
thanks
