HARARET INDICATOR PROBLEM
08.05.2020 20:36 # 1
serat21
hello friends 2011 peugeot 207 gasoline lpg vehicle.when I run the vehicle in the morning, the temperature indicator will not reach 90 in 5 km road will be fixed at 70, then it will be up to 90a after 1 km after 70e again it may be trouble
08.05.2020 20:36 # 2
Beyinci_Ugur
[QUOTE = serat21] hello friends 2011 peugeot 207 gasoline lpg vehicle.When I run the car in the morning, the temperature indicator will not reach 90 in 5 km road, it will be fixed at 70, then it will be 90a 1 km later, it will be down to 70e again.
Hi;
First of all, live engine data should be checked with the diagnostic device for exact diagnosis.
However, it is very likely that your problem is caused by the failure of the part called the thermostat to heat up the engine earlier and keep the engine temperature high.
Thermostat:
It is a mechanical or electromechanical valve that changes position with the temperature of the water between the engine block and radiator circuit.
beyinci_ug is 2017-10-21 01:11:35
