Handover is falling in second gear !!!
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:37 # 1
mbuyukavci
Hello there is a problem with a friend's car.
When I go to the second gear while driving, the car does not eat a gas, and the speed is falling, it comes to a stop, but it gets better and it does it only in the second gear. I ask for help from friends who have knowledge and experience. Tool 1,4 quicksilver 106
08.05.2020 16:37 # 2
okankrgz
I think the problem is exactly like this:
"the vehicle stops firing in the range of 2,000 - 3,000 rpm clogging the car and when the gas is pressed, the car bursts and returns to normal." if this is the case, it may be an air suction sensor ... if there is no problem with the idle sensor, there is a second possibility of ignition relay from it.
08.05.2020 16:37 # 3
okan4037
This tool is lpg l :)? Reviews
08.05.2020 16:37 # 4
mbuyukavci
Yes, lpg li vehicle. I can't tell you how it kicks, it knocks like a car that runs out of gas. My friend said after he got a tube
08.05.2020 16:37 # 5
okan4037
there is a tube in the atiker with red injector:) & nbsp; You can do it when it is cold, the tube regulator does not heat up or something, you can go to a different change or use it in the gas, I use it in the gas.
08.05.2020 16:37 # 6
djchaos
I always said that it is not important to install the tube, it is not important to have it attached to the master.
