Handmade air filter kit
08.05.2020 16:30 # 1
enilder
Hello friends, my car peugeot 306 1.6 8v griffe model, I bought a performance type air filter from my friend last night, I want to pull the rear part of the headlight with handmade pvc pipes and provide the air inlet more cool and fantastic, but 2-3 cables enter the cylindrical box where my car's original air filter is. One of them is even from LPG or something. What should I do with all the cables while creating the new filter kit? Can knowledgeable friends help?
08.05.2020 16:30 # 2
yavuz25
they are sensor cables. I think don't play with them at all. "Wink"
08.05.2020 16:30 # 3
enilder
Hello yavuz25
If I never touch the sensor cables, will I have problems when I install the new filter with the pipe?
08.05.2020 16:30 # 4
yavuz25
I don't think you will have any problems. "Wink" But don't change the original shape and location. yavuz25 2012-01-01 13:05:31
08.05.2020 16:30 # 5
enilder
As I said in my first post, the filter kit project that I have given my friends day has just ended, I disable all the cables and pipes coming to the filter box and put the filter with 70 PVC pipes and 90 degree elbows, it sounded good when I got on to try it. He turned back to his voice, looked down, disassembled, re-plugged it, but I couldn't get the real filter sound that I bought first, then I shook it a little bit again, but brought it home quietly, I left the car. I wonder what could be the problem? After he switched to lpg, did he stop giving voice?
08.05.2020 16:30 # 6
yavuz25
Did you disconnect the cables?
08.05.2020 16:30 # 7
enilder
There are 2 pipes and 1 cable in the filter box, the box cylinder has a sensor, a thin pipe that draws air from the engine cover, the other is a sensor about the LPG pipe, and I left them as a cable after removing them from the filter box.
08.05.2020 16:30 # 8
yavuz25
If you have not touched the sensors (not knowing), review the system you have installed. "Wink"
08.05.2020 16:30 # 9
enilder
There is no problem in the system, I made it into my own again, I put the original box or something but why did not I get a sound while driving it confused me "C
08.05.2020 16:30 # 10
acd org
the open air filter that you install will sound after a certain time, the institution will be connected for a month. I think I used the 307 engine to play with the latest cars & nbsp;
