Handmade 206 Apc Led Stop
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:03 # 1
<bugra>
I was hesitant to get apc stop or fk led stop to my vehicle. I add pictures ...
I will add pictures to the production stage later, I'm waiting for your comments ...
< img src = "http://img27.imageshack.us/img27/7350/62409365.th.jpg" border = "0" />
2009-05-10 16:39:15
08.05.2020 14:03 # 2
comondx
very beautiful brother
08.05.2020 14:03 # 3
MirakGTI
I think it was number 10 ..
We would appreciate if you share the pictures of the construction phase with us.
08.05.2020 14:03 # 4
GokhaN
it has been a successful work.
08.05.2020 14:03 # 5
<bugra>
the construction phase was in a hurry there are not many pictures unfortunately
material list
* 30 cm 150mm Fıratpen pipe :)
* 30 cm 100 mm Fıratpen
* body paste
* 100 and 80 Sanding
* bright black spray paint
* 50 80 degree angled LEDs + 12 v resistance
* 3 plenchets
* pattex adhesive, gray foil
* grinding and soldering machine < BR>
I broke the windows of the 3d stops
I dismantled all the mechanisms of the stops, I cut and screwed these pipes
I had to put the pipes in place to stop with the stops
because the pipes I installed came out, gaps were formed
I melted the inner mechanism of the stops with the soldering machine and molded it out: D I had to bring the bulbs closer to the front
the hardest part of the job was to pull and put together the paste, I applied 2 layers of paste and sanded it
at this time, I realized that the bodywork was not easy at all, it was very tiring: )
more I cut the transparent red color plexi from nra plexic
I thought how to lay the leds while installing the pastes
After placing the leds on the plencata, I cut them in the shape of the pipes and stick them inside
After long sanding operations, I applied 2 layers of paint and pasted the plexi with the plexi
< BR>
came harder than I thought but I got the image I wanted: icon_tup:
08.05.2020 14:03 # 6
Ismail
it is very nice
08.05.2020 14:03 # 7
emrs05
Thanks for sharing.
08.05.2020 14:03 # 8
Halal and beautiful!
08.05.2020 14:03 # 9
HakanGokdemir
Buğra has been beautiful, this is labor and health to your hand ...
08.05.2020 14:03 # 10
<bugra>
thank you guys :)
08.05.2020 14:03 # 11
Murat
Vayyy. It was really stylish. It's like the original :)
Goodbye, I hope it won't cause any trouble.
08.05.2020 14:03 # 12
t@lip
The view is number 10, I like it personally, you did a great job with pin pipe or something Talip_019 2009-05-11 13:50:14
