Handbrake Warning While Cruising (Solved)
08.05.2020 20:38 # 1
OguzhanKucuk61
Again, we are with a new problem, hello.
When I was driving, I received a low fuel warning sound as a result of a hard corner that I entered faster than usual. Sound was cut off at the corner exit. I also thought that the gasoline in the tank was leaning to the left so that it perceived a low amount of fuel. I didn't care much. This happened on Friday evening. (it was bend and not a highway.)
This morning, while going from Trabzon to Rize, I did not experience any setbacks on the highway.
When I entered the steep and rough curved roads towards Uzungöl side with 3 adult luggage half full in the vehicle, this sound came to the right or left. I set it up like a buoy or something went wrong. Then I noticed another bend. This warning was not a gasoline warning but a parking brake applied warning. The exclamation was in a separate place, the stop was in a separate place. ((I didn't see the stop text at the first start, exclamation was just happening. I think I don't know when it senses the handbrake is applied when driving.))
I was surprised I could not make sense and I continued. Then I got the handbrake warning again when I was forced to climb a steep hill. Meanwhile, because of the steep slope, the car had raised its nose and its ass was pressing on the ground. I make predictions by myself. But these are only estimates. I need your information and help.
Thank you if you read my story-like writing
I tried to explain as clearly as possible. Thanks.. oguzhankucuk61 2017-11-06 23:28:14
08.05.2020 20:38 # 2
onlycihan
Complete your brake fluid, this error will occur on sloped bends since it is reduced.
08.05.2020 20:38 # 3
OguzhanKucuk61
[QUOTE = onlycihan] Complete your error on sloped bends, as your brake fluid is missing, [/ QUOTE]
Thank god. I hope my lion will have this problem. Since the pedal got stiff, I was going to renew it already. Thank you oguzhankucuk61 2017-11-05 01:11:01
08.05.2020 20:38 # 4
talip206
99% brake fluid decreased. It usually crows when climbing uphill. In some models of the 206, it can give this warning when the water in the reserve water tank is diminished. If the hydraulic fluid is low, there may be a leak. Lean under the car and check the wheels from the inside. If there is an oil-like condition, there is a leak in the brake center.
08.05.2020 20:38 # 5
OguzhanKucuk61
[QUOTE = talip206] 99% brake fluid decreased. It usually crows when climbing uphill. In some models of the 206, it can give this warning when the water in the reserve water tank is diminished. If the hydraulic fluid is low, there may be a leak. Lean under the car and check the wheels from the inside. If there is an oil-like condition, there is a leak in the brake center. [/ QUOTE]
Hoping to handle 15-20 liras for the industry I will stop by tomorrow. I'll check it out before I go. Thank you. I hope there will be no bigger problem.
08.05.2020 20:38 # 6
OguzhanKucuk61
the @onlycih
@ talip206
Thank you. Today, adding the brake fluid, the problem disappeared. Dot4 laid master. The color was different. The blue in me was the yellow he put. He said there was no problem, the important thing was the dot value.
By the way, as you said @ talip206, I checked the tire for oil or not. The inside of the right rear tire seemed greasy to me. I did not look into the front tire. As you said, is the brake center problem waiting for me, sir? oguzhankucuk61 2017-11-06 23:31:27
08.05.2020 20:38 # 7
Kocak
Hello,
if there is oil in the tire, the brake center is broken and the hydraulics are reduced. I had the same problem, my brother.
08.05.2020 20:38 # 8
OguzhanKucuk61
Thank you, teacher. How much does it cost
08.05.2020 20:38 # 9
talip206
If there is oil, there is a leak. It does not cost much, it costs between 30 and 40 TL. They also work around 20 lira.
08.05.2020 20:38 # 10
OguzhanKucuk61
Thank you, teacher. I'll have him look too
08.05.2020 20:38 # 11
Kocak
It won't hold much, bro you can solve it for 60 70
08.05.2020 20:38 # 12
OguzhanKucuk61
The brake pedal was suddenly discharged when descending yesterday evening. It went down to the bottom. I could brake a little. I took a slope and left the car in a suitable place. I checked the brake fluid is missing, I tried to add the same again. Soon, I will take the master and take him to the vehicle. Let's see what
08.05.2020 20:38 # 13
onlycihan
Get past, there is a serious leak in brake fluid, then there may be a problem in the brake center, do not neglect
08.05.2020 20:38 # 14
OguzhanKucuk61
Thanks I am going to the master,
08.05.2020 20:38 # 15
Kocak
Get Well Bro
Kocak 2017-11-09 16:06:41
08.05.2020 20:38 # 16
talip206
Well, it probably caused weather due to leakage.
08.05.2020 20:38 # 17
OguzhanKucuk61
Thanks a lot for your wishes. Thank goodness it went without trouble. 50₺ workmanship 75TL piece money with a total of 125₺ right rear brake Center changed and the problem is solved. When I looked at the price of the piece later, I saw that the master was wearing 30-40 liras, but it was past :))
