Handbrake and Oil Light are on when moving.
08.05.2020 18:32 # 1
nurkann
++++ SOLVED ++++
Hello,
For the last 15 days, my peugeot 99 model automatic car has been flashing for 1-2 seconds under the hand brake light and engine water lamp and speed indicator suddenly on the dashboard, especially when climbing up and turning into curves.
In the first place, I thought the vehicle stopped, but the vehicle does not stop, continues its movement and the lights go off again in 1-2 seconds. It does this frequently, so 4-5 km of road does the same thing at least 5 times.
Why might it originate? Does it cause a serious problem? I'm waiting for your help
Thanks.
nurkann 2014-05-12 21:54:56
08.05.2020 18:32 # 2
Serkan
If there is no water shortage, there may be a problem in the circulation, it may cause a serious problem.
08.05.2020 18:32 # 3
nurkann
Thank you, but starting from what I read on the forum, I wondered if it might have something to do with brake fluid because it burned in the handbrake beam?
08.05.2020 18:32 # 4
Serkan
Sir, the handbrake light does not only illuminate on brake related problems, it also illuminates in the sense of `` attention '' with other malfunctions, for example if the oil pressure drops in the vehicle, it also comes on with the oil lamp. There is even information about this in the user manual.
08.05.2020 18:32 # 5
nurkann
I think that this problem is correct if we connect it to the computer.
08.05.2020 18:32 # 6
307imbenim
water might have gotten into the diesel filter. The same thing happened to me.
08.05.2020 18:32 # 7
Serkan
[QUOTE = 307immy] water may have escaped the diesel filter. The same thing happened to me. [/ QUOTE]
My vehicle is a petrol teacher, probably a mistake when connected to the computer
08.05.2020 18:32 # 8
tprkozd
your vehicle is likely to decrease water
08.05.2020 18:32 # 9
nurkann
[QUOTE = tprkozd] it is likely that your vehicle is reducing water [/ QUOTE]
We're talking about engine water, right? If so, yes, it does, but it has been doing this for a long time.
08.05.2020 18:32 # 10
Burak
Your problem is like the video on the subject I gave at the bottom, sir?
The vehicle in this video was me, room 106 was automatic gear, the problem was the lack of oil, 1 drop of oil was left in the engine, you may have a lack of water or a lack of oil.
Burak 2014-05-11 21:41:01
08.05.2020 18:32 # 11
nurkann
[QUOTE = Burak] Your problem is like the video on the subject I gave below, sir?
I get the error just like this. The stop and parking brake oil lights are on. Let's look at the oil tomorrow, let me look at the water, hopefully we will solve it this way.
08.05.2020 18:32 # 12
Burak
[QUOTE = nurkann] [QUOTE = Burak] Your problem is like the video on the subject I gave at the bottom, sir?
It is highly probable that one of these reasons is to check the thesis at the time.
08.05.2020 18:32 # 13
DeRyCK
check brake fluid, most likely there is deficiency.
08.05.2020 18:32 # 14
wlkn87
There is a problem with 90% brake fluid hydraulic leaks when the brake fluid decreases that light comes on 1 month ago
08.05.2020 18:32 # 15
KILIC
Friends would be permanent, even from brake fluid. My humble opinion is that the engine coolant is running low. The vehicle is probably running low on water, as it is just uphill and turning around a bend.
08.05.2020 18:32 # 16
kuscu38
Teacher, clean your car in the weekend, check the radiator, check the brake fluid, check the rear and front pads, if possible, look at the hand brake ropes. engine oil, steering hydraulic oil is a complete look, if there is no problem, have your car connected to the computer. If there is a malfunction, make sure that the vehicle's water is decreasing and the heater core and radiator are checked. Is there any water discharge from the exhaust? These are the ones that come to my mind.
08.05.2020 18:32 # 17
nurkann
I checked the oil this morning, there was no oil left in the car, the water was normal. I will add oil at noon. Let's see if the problem will be solved. Thank you all for the answers.
08.05.2020 18:32 # 18
kuscu38
[QUOTE = nurkann] I checked the oil this morning, there was no oil left in the car, the water was normal. I will add oil at noon. Let's see if the problem will be solved. Thank you all for the answers. [/ QUOTE]
have other things checked. The problem will disappear, even if the problem of lamp extinction does not disappear, do not be afraid.
08.05.2020 18:32 # 19
Serkan
The engine water lamp you mentioned in the first message, I think it was the oil lamp
08.05.2020 18:32 # 20
kuscu38
[QUOTE = Serkan] The engine water lamp you mentioned in the first message was an oil lamp I think [/ QUOTE]
Thumbs UpThumbs UpThumbs UpThumbs UpThumbs Up
Page : / 3
