hand brake warning
08.05.2020 20:26 # 1
mustafa46
my car peugeot 307 1.6 technoplus .. the morning I started my car to go to work .. after we went 2 km or so, my car's screen brake warning and stop warning came out and started to sound on the road ... then it got better then why did not it repeat?
08.05.2020 20:26 # 2
talip206
If he is doing on a slope or on a turn, the brake fluid has decreased. Check it out. Generally it gives warning when climbing uphill due to sensor position.
08.05.2020 20:26 # 3
onlycihan
Just like the hydraulic fluids are low, it gives us such warnings, and it is a good thing to give them, we will not control anything.
08.05.2020 20:26 # 4
Peugeot35
it gives because the brake fluid is low. There are two brake fluid reservoirs, the reserve tank is at the front, check if there is a shortage or fill it, or look at the tank above the brake center.
08.05.2020 20:26 # 5
mustafa46
when you say above the brake center, where exactly is it
08.05.2020 20:26 # 6
whisky
[QUOTE = mustafa46] When you say above the brake center, where exactly is it [/ QUOTE] When you open the hood, something like a little white canister in front of the window, you can open the lid and look at the hydraulics.
08.05.2020 20:26 # 7
mustafa46
I looked at it last night. There was no oil. I looked under the car. There was no oil dripping. I bought dod 4 oil in the morning. I put it in the yarn.
08.05.2020 20:26 # 8
talip206
[QUOTE = mustafa46] I looked last night, there was no oil left ... I looked under the car, there was no oil dripping .. I bought dod 4 oil in the morning, but I put the yarn to the industry tool .. [/ QUOTE]
It's probably missing from one of the brake centers. Lean down and look at the inside of the wheels from below. The leak is evident, the oil is always covered. It happened to me the other day
