H7 Led Headlight
08.05.2020 20:03 # 1
Sercan Mungan
Hello, nowadays I intend for h7 led headlights, I have met many brands and models.
08.05.2020 20:03 # 2
OguzhanKucuk61
Follow-up .. I have the same enthusiasm as well :) I am very passionate about the flash effect when the selector is fired. A BMW is coming past me, throwing a patty selector. I ran away, passed, sw megane :)) I was amazed. I want the same :)
08.05.2020 20:03 # 3
iammanover
I recommend photon
http://www.photonturkey.com/h7-led-xenon1
Flash effect is very high
08.05.2020 20:03 # 4
Sercan Mungan
The lightning effect is gorgeous 😊 The lighting range in the short is also successful but I have heard that it is weak in the long range. Sercan Mungan 2016-12-03 11:23:34
08.05.2020 20:03 # 5
OguzhanKucuk61
I must not decide without trying. With the original halogen attached to one headlight, I think it is necessary to install the led bulb on the other and see the difference and make a decision.
08.05.2020 20:03 # 6
Sercan Mungan
I also know that the back cover of the headlight cannot be fully closed in some vehicles as the back of the headlight is large.
08.05.2020 20:03 # 7
ggitaristt
Follow-up .. But I know that cold light is not effective at long distance.
08.05.2020 20:03 # 8
OguzhanKucuk61
Isn't there a led h7 with 4300k?
08.05.2020 20:03 # 9
OguzhanKucuk61
I also looked at the prices, says 200-300 or something? While the normal osram h7 halogen is 10 lira, isn't it strange that the price is so different? Am I looking at the wrong sources?
08.05.2020 20:03 # 10
Sercan Mungan
Its long illumination is weaker in range than other halogen bulbs, but the short illumination of LEDs does not require long ihtiyaç
There are around 120 lira Niken brand, but I do not know about its quality.
08.05.2020 20:03 # 11
ggitaristt
Thank you we have a car for 17 years, only 1 light bulb exploded. there is no point if the bulb will fail in 1 year.
Recently, I said, let me get the night breaker of osram. But its color and lighting are excellent.
Conclusion: If the bulb we will buy is not as good as the original led of new cars, we will have thrown our money a bit. Because electronic material is also a good luck business made in China.
Edit: I walk around with the headlight open even during the day, so it should be long lasting.
ggitaristt 2016-12-04 15:43:38
08.05.2020 20:03 # 12
Sercan Mungan
As far as I have researched, the accessories do not provide any guarantee, but those sold on the net have stated that they provide a 1 year warranty. Actually, LEDs are long-lasting but I find it useful to choose brands such as photon, Philips, osram provided that they are quality.
08.05.2020 20:03 # 13
OguzhanKucuk61
Something like that I'm talking about. It has the same input as the normal socket. The only difference is that instead of a halogen bulb, it's LED. The price is also very affordable. Although, when I look at the comments, people are not very happy with the lighting, but I do not know.
08.05.2020 20:03 # 14
OguzhanKucuk61
There is also such a variety. There is another piece in the part that should be the socket. Is this xenon? Is it because of the price difference?
08.05.2020 20:03 # 15
Alicilik
Do not take the led with a true lumen value below 4000 and do not baton it.
Do not expect performance in led headlights, especially in high beam headlights, without lenses.
My advice is to buy a fan-cooled led bulb with 5000 and above lumen.
08.05.2020 20:03 # 16
OguzhanKucuk61
[QUOTE = Buyer] Do not take the led with a real lumen value below 4000 and do not baton it.
Thank you brother, is this the second piece I put on the bottom fan cooling?
08.05.2020 20:03 # 17
Alicilik
[QUOTE = OguzhanKucuk61] [QUOTE = Appealing] Do not take the led with a real lumen value below 4000 and make a baton in the empty space.
Thank you brother, is this the second piece I put on the bottom fan cooling? [/ QUOTE]
Yes, he is a fan, but as I said, you cannot get much efficiency with such low light bulbs. These COB LEDs give parking distance at short distance. For example, it is used for cakar but road lighting is disastrous. If you buy 5000 lbs per bulb, the taste of the led comes out. It was close to 1 year, I'm very glad. I bought it in my other vehicle and I am very satisfied with it.
08.05.2020 20:03 # 18
OguzhanKucuk61
Thank you very much for the information. Experience is important :))
