H7 Headlight Selection?
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 20:16 # 1
OguzhanKucuk61
Brothers and sisters noticed while driving left dipped beam.
I use the classic osram h7 55w. Since I will renew the left side, I think there will be a Gloss difference with the right side. I plan to buy a double. I looked at the net, osram has a 100w model. Is there any inconvenience to use it?
Sounds like plain logic provides twice the Brightness Am I wrong? I also aspire to the white bulb. I know bad visibility in the fog in the rain, but the weather gets warmer. I think it looks very stylish. I am waiting for your H7 suggestions ..
And why are these bulbs cut? It happened to me 2-3 times at different times right and left separately
08.05.2020 20:16 # 2
Gokcesel
As you said, there will be a ton difference so it will make more sense to get double. I put photon xtreme vision on the fog and it has a beautiful yellow skin. If you want white, there is diamond vision, you can also choose it. I used it in 206 but one of them exploded so I had to change it.
You can experience high-watt reception, darkening in the headlight, socket melting etc. You can get a light bulb at its original value. If the light bulb bursts in a short time, there may be a problem with the electrical installation, but I don't think it is a problem right now. If the bulb you just bought and installed bursts in a short time, then you go to an electrician.
08.05.2020 20:16 # 3
OguzhanKucuk61
Maybe it had been 4-5 months. As soon as I plug it in, there is no such thing as an explosion in a short time. Continue to 55w then :) let me see the diamond vision thank you volume :)
08.05.2020 20:16 # 4
OguzhanKucuk61
I know our longs are h7, right?
Is it possible to have a flash-effect selector without a lens, just by installing a light bulb?
YouTube link
08.05.2020 20:16 # 5
BLACK LION
[QUOTE = OguzhanKucuk61] I know that our longs are h7 is it true?
YouTube link [/ QUOTE]
Yes it is possible. There is a led xenon. The lens is not a must. It flashes by flashing in the selector. The price is 150 TL. But if you want something quite long-range, it's 500-600 tl. around price.
BLACK LION 2017-04-01 22:07:07
08.05.2020 20:16 # 6
OguzhanKucuk61
How much you work, you ll gain the amount for your work
I'll take a bulb for 20 lira and sit down
08.05.2020 20:16 # 7
Gokcesel
Yes, long h7 but I think the LED is not suitable for the purpose of lighting or lighting, just visualization when throwing the selector. If you need it in a dark area, you will have trouble.
As you said, buy a good quality light bulb. Approve I want white too, but whatever the brand of the bulbs on the vehicle illuminates very well, so I never change it.
08.05.2020 20:16 # 8
OguzhanKucuk61
I read bad comments about white, it was very ineffective for long. Probably I will continue on the same road.
08.05.2020 20:16 # 9
Gokcesel
[QUOTE = OguzhanKucuk61] I have read bad comments about white, it was very ineffective for a long time. Probably I will continue on the same road. [/ QUOTE]
I highly recommend Photon Xtreme Vision if you are getting yellow Thumbs Up
08.05.2020 20:16 # 10
OguzhanKucuk61
[QUOTE = Gokcesel] [QUOTE = OguzhanKucuk61] I have read bad comments about white, it was very ineffective for long. Probably I will continue on the same road. [/ QUOTE]
Okay. Let me take them from them, I looked at them very well :)
08.05.2020 20:16 # 11
GokhaN
white bulb fln story or xenon fit max 6k lower if possible if lower k
or standard bulb I use brand possible narva, I'm glad it goes longer than osram in my vehicles
08.05.2020 20:16 # 12
OguzhanKucuk61
I intended Xtreme vision a brother, but do you say the brand you call will be more efficient?
08.05.2020 20:16 # 13
ggitaristt
Personally, I am thinking of night breaker laser. However, the lifetime of 1 year, I haven't used it for 2-3 years. Excessively bright or painted lamps will have a short life.
I use the 10 TL bulb of Osram .. For 17 years, no bulb has exploded.
