Guys, I have a few problems and questions
08.05.2020 20:19 # 1
omer35
hello friends ... my car 2009 model 308 lpg li.car nearly a month ago the engine malfunction lamp lit, the antipollition fault text appears on the screen and the exclamation mark is on. the car is shaking like a tractor and the car does not go even though I press the gas, it accelerates very slowly as it feels like a fan, even though there is no heat, the fan turns on and does not shut down. When I go to gasoline, it goes back to normal when it goes for a while. I got ZAVOLİ lpg. From time to time, the vehicle started to fall out of the traction, and I did not know the connected connection, but when I was driving with the car yesterday and the heater was turned on, it suddenly hit 120 and the stop text appeared on the screen. . Could you enlighten me. Thanks ...
08.05.2020 20:19 # 2
Furkan979
It was like this when I burned, the car was resisting not to go, I always thought it was LPG, I deleted it from my phone, next month, I will take it to the service soon.
08.05.2020 20:19 # 3
First of all, welcome to us. Replace the spark plugs and check the coil may be faulty. then replace the lid of the reserve water tank, which is not normal for the vehicle's overheating 120. fan relays and temperature sensor - the thermostat should be checked. After checking and replacing the parts that need to be changed, use it at 100-150 km gasoline, then switch to LPG, this type of misfires usually from the ignition system, but if the LPG map sensor and temperature sensor are defective, they may also be caused by them.
