Guarantee if we install xenon on the 208 lens headlight?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 18:37 # 1
Advantan
As you know, the upper packages of 208 have lens headlights, but the normal yellow light changes the work, it does not look beautiful,
I want to buy and replace the Osram H7 55W Unlimited bulb, will the vehicle be out of warranty?
the Advanta 2014-06-15 00:38:32
08.05.2020 18:37 # 2
Serkan
The bulb you mentioned is not xenon, the halogen bulb does not have the slightest effect on the warranty.
08.05.2020 18:37 # 3
Advantan
Thank you, Mr. Serkan, when I examined a little bit, the light bulbs of osram are like yellow light so there is not much meaning I decided to buy philips 5000k diamond h1
08.05.2020 18:37 # 4
Serkan
Isn't your bulb type H7? Check it out, I think it should be H7.
08.05.2020 18:37 # 5
Alicilik
Let's first agree on this. H1 and H7 are very different types of bulbs. Bulbs are divided into many types according to size and socket type. You will often see these as the H series (H1-H3-H4-H7 .....) as the D series with more xenon or the 9000 series. Make sure the bulb in your priority headlight.
For xenon,
My advice is not contaminated. Because halogen lenses do not look as good as halogen when xenon is attached. I tried it on my own car. I have a solenoid curtain in my own vehicle. He uses one ampoule and a hard bulb is halogen like yours. I took xenon and tried, but the result is fiasco. Neither line remains nor light. I removed it in 5 minutes.
If you want to make a serious improvement to your headlight, I would like you to upgrade Osram's NightBreaker series with the light bulb suitable for your vehicle.
But there is no need to change your lenses. It is a very expensive job.
