Greetings friends air conditioning problem war help :(
08.05.2020 16:04 # 1
volkan22
Friends Hello again.
today i brought my car's air conditioner to gas: S
the air conditioner pressed the car into gas, but after that ....
I OPEN THE AIR CONDITIONER AIR CONDITIONER COMPRESSOR IS COMING ON AND OFF.
FANS FILLED AS 2 SIDE INSANE ..
I LOOK AT THE COMPRESSOR OF THE AIR CONDITIONER, GETS 10 SECONDS, GIVES LESS COOL.
DISABLED AFTER HOP
ALSO WHEN GOING ON THE ROAD, PLAY, PLAY, SOUNDS ARE COMING HIGHLY WHILE THE CAR WAS HIGHLY RUNNING THE FANS WILL BE BORDER
THE COMPRESSOR IS IN THE CIRCUIT EXITS 1 SECONDS, AFTER THIS SIZE REPEATS
THE MOTOR OF THE CAR IS LIKELY AS LIKE.
THE INDICATOR LIGHTS SHALL BE SHOCKED ON THE ROAD: S
(((((((ISIN BIZARA SIDE GOTURDUGUM OTO ELEKTRIKCII SAY ME IS A FUN
My fans do not blow MUSIC FALAN SILAN
I WILL SURROUND THE BUMPER
THERE IS NO FANS BACKBACK HOW IT COMES INTO CIRCUIT AND EXITS.
I DID NOT BELIEVE: S))))
THE AIR CONDITIONER FANS FILL AS FALLY WHILE THE CAR IS GOING ON THE WAY THE CAR COMPRESSOR COMES TO THE CIRCUIT AND SOUNDS TO PLUG IT
THE VEHICLE IS CONSIDERING WHAT DO YOU KNOW HOW I DON'T Deceive The Electrician Me
PLEASE CLICK ON MANUAL LOAD FALAN LAS PRINTED HELP PLEASE: S
MY VEHICLE PEUGEOT 306.
08.05.2020 16:04 # 2
volkan22
ALSO WHEN THE CAR IS GOING ON THE ROAD, IT WILL TAKE A LOT OF NORMAL: S
THE AIR CONDITIONER DOES NOT COOL: S
THE COMPRESSOR IS ON THE GO ON THE WAY COMING OUT AFTER 1 SEC.
CAR'S MACHINE 2.0 16V
PLEASE HELP I DON'T BE Deceived PLEASE
08.05.2020 16:04 # 3
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14394&title=byk-yaz-fontlarna-dikkat
08.05.2020 16:04 # 4
volkan22
Greetings my brother I had no knowledge, I learned that I will try to pay attention next time,
I'm sorry ...
08.05.2020 16:04 # 5
Muhammet CAKIR
If there is no such problem before gas is pressed, it is because of the damage caused by this gas, I think it has been printed too much or there are gases made in China, it has damaged the compressor and it has ruined the compressor.
08.05.2020 16:04 # 6
volkan22
Well, the fans are freezing like crazy. The fans don't blow on me.
I look at the fans and they freeze fast
08.05.2020 16:04 # 7
iibrahimm
if there is a blow on the console or that roof keeps working
08.05.2020 16:04 # 8
volkan22
the console blows freezes for 10 seconds, the compressor starts to cool, then the compressor turns off
comes out: When I run it for the first time, it runs for 10 seconds and then stops for 5 seconds, then the compressor stops.
In other words, when the compressor donunce stops the cold air coming, the cold air stops immediately: S
the car is starting to give a cold in those 10 seconds: S
and as I go down the road, there is a sudden motor contraction, as if braking on the sanitary: S
volkan22 2011-09-04 07:58:28
08.05.2020 16:04 # 9
algosfides
Brother, what did you do, did you solve the malfunction? I have that same problem.
