Good morning, there are a few things I wonder ...
08.05.2020 14:15 # 1
diabolicfb
Hello everyone first
Friends I am a user of the 2002 model xr peugeot 307 (new).
- How can I test the operation of the ABS system in the vehicle. Because there are intermittent hitting sounds in the ABS system in other vehicles, but there is no such sound in my car, there is ABS, but what is the probability of this being disabled for a possible reason.
- If you want to listen to tape radio for a while after turning off the ignition of the vehicle, it is possible to turn off this mode when you write "economy mode active" on the screen and nothing electrical works without starting the vehicle?
- The vehicle can be lifted and lowered automatically by the driver in 4 mosques. (It can be opened and closed without stopping again) However, this does not only work on the driver's door window, so I have to press the button continuously for opening and closing. Is it normal?
- Is there a lock so that nobody can open the doors from the inside except the driver?
- Also, how many kms of gasoline left in these models can be built, ie is there a trip computer or can the trip computer be integrated later?
- The signal lever is very sensitive, does it have a setting? (I look at it when I have completed the right turn, it is on the left signal :)))
08.05.2020 14:15 # 2
hello my car is 307 ..
As soon as I get to Abs, I can feel the sound of knocking and knocking, there is no problem in that matter. In my car, this noise is heard in general abs vehicles, but I could not understand why you cannot hear it.
In addition to the "economy mode active", your eco-mode vehicle is automatically activated for the battery not running out. Why do you want to make a very special feature?
I couldn't understand that you can control all of them by the driver of the glass. The issue is that the driver can hurt the left rear window in half and remove it with a single button.
There is a small clasp sign that must be located right next to the place you burn 4 or 4 for a lock inside the doors.
The screen has voiced settings, as well as the road computer ... you can change the information on the screen by pressing the button in the middle of the arm that will erase it.
There may be a malfunction in the signal arm, or it is not so sensitive.
emrah 2010-05-24 10:08:09
08.05.2020 14:15 # 3
diabolicfb
Hello Emrah, first of all, thank you for the answer.
I do not know how hard I should hang in the case of ABS, usually I didn't hang on the brake suddenly, maybe because of this.
I think Economy Mode is a good application in my opinion, can I just close it? If we want to listen to a few songs in picnic areas, we can't even listen to the first song :)))
The window closes with one touch on the other windows that apply to my driver's window.
My friends say that if the 2002 model is in the vehicle, it is unlikely to be a trip computer. Also, does it not need to write TRIP on the wiper arm or signal arm?
Thanks again buddy ..
08.05.2020 14:15 # 4
H-a-d-i
ABS: the vehicle can be connected to the computer and checked for an ABS error or not. Perhaps it is not among its features or XR is offered as an option.
economy mode: does not turn off. it is also a very good thing. If you forget the tape on when you go home in the evening, it closes after 10 minutes.
glass buttons: 307s chronic failure. driver's window switches have 2 stages. in the first stage, it descends as much as you press, in the second stage, the glass is opened completely. your button is broken.
door lock: are you asking for the lock that you ask for not to open it from the outside or for other passengers? There is no child lock.
trip computer: can be mounted. but it will be very costly. my estimate may be between 500-1000 TL.
signal lever: I think yours is broken. Pretty normal for an 8-year vehicle.
08.05.2020 14:15 # 5
okan77
No child lock on the back doors? Available in 2005 model ...
08.05.2020 14:15 # 6
bulent 77
child lock is available in a 2002 model vehicle, the driver window control is not working properly because it has to go down at once, if you brake hard in an area suitable for abs, you will know whether it is working abs or not, I agree with the signal arm sensitivity, I am also complaining, I think this is the trip computer. The models are not available, ecenomy mode is also activated for 30 minutes, so the battery will not be a problem because the headlight tape etc. are completely closed.
08.05.2020 14:15 # 7
mabolla
This model already had a signal arm problem across the 307s, it is interesting that there are a lot of people going to the services because it was broken, they later fixed it when it was a chronic problem. I think you should also change it.
08.05.2020 14:15 # 8
diabolicfb
Thanks for the answers, guys. Thanks to you, I got some information and ideas. The economical mode is a good thing, the signal arm is a little sensitive, the windshield button is faulty and my moderator says it is true, I think there is no ABS in my car because there is no disc on the rear wheels so I do not know how it is impossible to thank you. ...
08.05.2020 14:15 # 9
mertcan atakan
Firstly, good night everyone ... I got 207 friends this day
When I came home, ECONOMY MODE WAS A SOME TIME TO THE MODE.
08.05.2020 14:15 # 10
GokhaN
[QUOTE = mertcan atakan] firstly, good night everyone ... I got 207 friends this day
A mod that is required to prevent that battery from running out does no harm to you.
08.05.2020 14:15 # 11
mertcan atakan
BUT WHEN I RECEIVED THE CAR, THERE WAS NOT HAPPEN .. SIZE BIT.
08.05.2020 14:15 # 12
there is nothing to be afraid man eco mode is activated to prevent the battery from running out.
08.05.2020 14:15 # 13
serkan24577
If the abs light is on the left corner on the screen before starting the car, it does not have to feel like it slips under the foot when it touches the brake.
When tyepe ignition is switched on, after 10 minutes, it automatically switches to economic mode unless you open the ignition.
I guess you want to tell that on the window, you think, when the driver's button presses the glass button, you have to automatically lift and lower the others. This is normal, because if you look at the icon on the button, you can see that the glass image will be half glass image in the others.
What do I lie? I don't have mine. Locking it from the inside. I close it from my alarm.
08.05.2020 14:15 # 14
furkan
eco mod is a low battery
08.05.2020 14:15 # 15
Haksen016
First of all, good morning to everyone, my brother, if the vehicle gives an economy mode alarm, watch out. You can stay on the road at any time, have the battery checked as soon as possible. I know where. because I was less on the way. For the first time, my car gave this alarm a short while ago. I thought like. But while I was thinking that I had a problem with the battery due to symptoms such as late cranking, the clock resetting continuously, my vehicle could not get a starter after a while. We were expecting such a thing from Allah that we have already filled the battery in the battery, and we have changed it.
08.05.2020 14:15 # 16
mertcan atakan
Good evening, friends .... I will ask for help ..207 original installation sound power is not bad but I want to feel the toughness of the press. I want to put the amplifier.
08.05.2020 14:15 # 17
oguzhan29
Connect to a good sister, go to a systematic, let's connect a beautiful amp
