Golf Clutch Problem
08.05.2020 18:11 # 1
Burak
My friends car is not a pug, but I thought I might ask you because it is a familiar problem. I could not solve the pressure from the clutch, it becomes normal when the work becomes normal, there is no problem.
Burak 2014-01-07 21:49:25
08.05.2020 18:11 # 2
Alicilik
Could it not leave the wire?
08.05.2020 18:11 # 3
Burak
[QUOTE = bitter] If I change 10 thousand km of press brake, I do not use a car and I think it's wrong ... 5 b, these are the things that are not happening for the car. [/ QUOTE]
I don't know, brother, I stayed a lot today.
08.05.2020 18:11 # 4
Burak
[QUOTE = Receiving] Couldn't it leave wire?
If there is a lot of traffic in the place where it is too much, wouldn't it be the same?
08.05.2020 18:11 # 5
samet206
It happened to me in time, it got better with time, I don't understand how it happened when the first change changed, the pressure was the same as the linings. He leaves the pensioner in a shorter time than his normal life.
08.05.2020 18:11 # 6
Burak
[QUOTE = samet206] It happened to me and it got better with time. I did not understand how it happened when the first change changed. They use the room to have some problems and leave the pensioner in a shorter time than his normal life. I recommend you to look at the clutch wire and the ball.
I am planning to go to the master on the weekend or you can not go to traffic in Istanbul. I will open my own business.
