Going to Gas & Stopping Problem
08.05.2020 20:42 # 1
onklc06
Good evening. I replaced the car's thermostat and radiator hoses that had faced decay. After that, the time to go to the gas in 2-3 minutes increased to 20-25 minutes (air between 2 and 5 degrees). While 2 clicks were made as snaps, 5-6 times were repeatedly giving clicks and went to the gas. I reset the gas setting and went to work on gasoline because I was in a hurry (between 2km master and workplace). When I went to the test later, the passing time was again 15 minutes. In fact, this time there was a problem of stopping when slowing down or turning left and right. I think I need to increase the gas setting, so what could be the reason for switching to gas?
08.05.2020 20:42 # 2
If the click sound is constantly coming to the gas, there may be a problem with the gas cutters, hodja. I think have the lpg system checked. Have a look at the lpg regulator.
