glow plugs
08.05.2020 19:40 # 1
poyraz1389
Friends peugeot 307 hdi I have a car with glow plugs, there is also a problem, said that we have to insert the engine top cover, the master said to me that it will cost 1000 liras and over, the removal of the engine top cover because of the glow plug is nonsense. You can help. What should I do? I am printing marsa.
08.05.2020 19:40 # 2
timo206
Hey, 1000 TL and over. How did the glow plug diagnosed?
08.05.2020 19:40 # 3
baya1994
Forcing the car to run, you will run out of the battery, the pump will be on the sides. It used to be used when the blood pressure is dying. There is something like that to him. You can get 20 Turkish liras between 100 Turkish liras and go to another master.
08.05.2020 19:40 # 4
childrenofgrave
First of all, get well soon. As the friend said: The glow plug is 100 TL in a set. Workmanship, let's get maximum 50 TL. But the trick is to remove the spark plug. The engine must be turned on if the spark plug is broken and parts remain inside. Did your master come and tamper with the car inoperative; or did the car never work after the master struggled?
Now don't panic if the vehicle does not have a part breaking condition related to the glow plug. Try to start the car at noon on a hot day. But when you turn on the ignition first, wait for the glow plug light on the instrument panel to go out. Wait at least a few minutes, even if it does not go out. Then try to run it persistently.
The same problem happened to me on my first car. 2004 1.4 at TDCI Fiesta.
08.05.2020 19:40 # 5
childrenofgrave
Of course, this is what I said if the problem is in the glow plug ... The problem may be something else. If diesel is air, you should pump diesel to the engine as your friend says. Or the diesel pump may be malfunctioning.
Pay attention to the display information display. Turn on the ignition to see if the spark plug lamp goes out. There is no one but there is another possibility; Let the tool immo be reset?
childrenofgrav to 2016-02-21 21:09:48
08.05.2020 19:40 # 6
Halil5759
When the ignition is switched on in my vehicle, the glow plug's lights never light up, the master in the service connected it to the computer, he said that the 3 and 4 spark plugs were faulty, but he did not struggle because there was no problem in the operation of the car, he said that we change the 4 of the spark plugs when the others are broken. He said that the lights should not light up in the normal weather when he stepped in -5 -10s, I did not know how accurate I am the liar of the master
08.05.2020 19:40 # 7
childrenofgrave
As soon as the ignition is switched on in my vehicle, it burns for 1-2 seconds for testing purposes and goes off immediately. Because of the climate, we do not have a heating spark plug problem even in winter.
The glow plug has three main functions. The first one is to provide the first operation by heating the air taken by the engine during the first start; the second is to prevent the temperature of the cylinder from decreasing when the injectors cut the fuel on long downhill slopes; The third is to prevent changing pressure from inefficient compression, as it climbs higher. These are very unusual possibilities for places like İzmir and Aydın. That is why we do not experience the disadvantage of the broken glow plug.
I only replaced the spark plug once before. He came to my head in January when he was in Istanbul. Workmanship took a total of 20 minutes. There is no difference between spark plug replacement in normal gasoline vehicles as workmanship. But as I said; If the piece is skewed or broken because it is long, then the work will grow. Even my vehicle was broken, but we were able to coincide with a spiral guide with a magnet tip. By the way, I don't know if the situation is different in our engines. So if the spark plug cannot be removed without opening the top cover, it would be a big surprise to me :)
08.05.2020 19:40 # 8
xmen
None of the heating plugs in my vehicle are not working, the master in the authorized service will not have any problems in my own vehicle.
08.05.2020 19:40 # 9
cottons1903
We changed the glow plugs on 206 of my friend this Saturday. While the mechanic was dismantling one of the spark plugs, he broke and took off with some effort without removing the top cap. 150 TL including labor.
08.05.2020 19:40 # 10
bb-mahmut
In the case of heating spark plugs, the car does not work completely. My friend has a mistake in this work. If it is true what it says is 1000, it is a little bit an exaggeration to say 600 to 800. the problem is that the table 2 exhaust manifold gasket cost 3 intake manifold gasket cost 4 is ready to clean while maintenance costs 5 felts fln is saying the list goes. It is useful to take it to another master, so look left and right, press the starter, aaa, it is not called a spark plug, it cannot be understood without connecting it to the computer, you say that the vehicle is not working at all.
08.05.2020 19:40 # 11
bb-mahmut
the vehicle cannot work for a number of reasons
1) pump failure
2) plugs
3) ignition coil
4) injector
5) battery is weak
6) vehicle overwhelmed
7) king sensor
8) brain
If you have noticed these, I did not write a spark plug :)
I have never seen or heard anyone who has not walked the car because of such a problem
08.05.2020 19:40 # 12
childrenofgrave
[QUOTE = bb-mahmut] the vehicle can't work for a number of reasons.
1) pump failure
2) plugs
3) ignition coil
4) injector
5) battery is weak
7) king sensor
8) brain
Mahmut take out the number "2". There is no spark plug in the diesel vehicle.
