glow plug replacement
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 16:20 # 1
cerci07
The frequent patch of the glow plug warning in the first run of the 1.4 fiestan started to disturb me, I checked it out to see if there was a malfunction, so I wanted to share with you how it was inserted.
want to follow the way for the socket
1 insert the pole of the battery
2 insert the air filter box 5 screw holding the places marked with red arrow
there are heating plugs in the places indicated by the green arrows
3 the air pipe of the egr valve the socket is marked in blue
In the back part of the 4-filter box, the cables should be rough. unplug the attached part without wiring
insert the screw and clamp of the egr valve pipe after removing the 5kbi
6 first & nbsp; we insert the screws holding the spark plug wires, we remove the cables, be careful not to drop the screws to the back, then you may need
< br>
We will need the key in the picture to insert the spark plugs 8
When inserting the spark plugs, we must be careful not to damage the screw places we inserted
to see if it is defective after removing the spark plugs. we can connect it to the battery, it is strong if the tips are red. We can control it with the device as we see in the picture. We bring the device to the setting of ohms. The rugged spark plug should be between 0.6 ohm and 1 ohm. Mine gives 1.1 - 1.2. = "http://img513.imageshack.us/img513/7228/pb040064.jpg" border = "0" />
to see if spark plugs are broken There are different methods for
will be the last spark plug that you will have the most difficulty and keep a mirror with you
08.05.2020 16:20 # 2
nice share thanks.
I didn't need to learn the diesel engine because I always use a gasoline car. we can check or change.
thanks.
08.05.2020 16:20 # 3
Good job. Thank you for sharing.
08.05.2020 16:20 # 4
badcombatant
nice work, especially if you want to specify the ohm value of the spark plugs, good information
your work & & nbsp;
08.05.2020 16:20 # 5
Let me share a very useful ... Good health.
