glow plug
08.05.2020 16:38 # 1
Bugra
friends 206 1.4 hdi engines glow plugs should be changed after how many km or should it not be changed if there is no problem? or let me ask a knight how do we know if there is a problem? Does the tool not work or does it work?
ii forums "Smile"
08.05.2020 16:38 # 2
The glow plugs are used as much as I know. It is not changed within a certain kilometer.
Since the glow plugs operate under a certain temperature, it is not understood whether they are bad under bad weather conditions. When the vehicle does not start in very cold weather, it is superseded by the glow plug. Reviews
08.05.2020 16:38 # 3
Bugra
[QUOTE = koliva] Glow plugs are used until they break down to the best of my knowledge. It is not changed within a certain kilometer.
then should I understand that? it is not very cold here. my spark plugs are faulty but they don't show themselves because the weather is not cold "C
08.05.2020 16:38 # 4
[QUOTE = bugrature]
[ / QUOTE]
Yes it is. If you want to try to see if it is working or not, you can stick it in. Do not worry if the weather is not cold "Smile"
08.05.2020 16:38 # 5
inceyasar
My friend's glow plugs are working under -4 degrees I know. i have 1.4 hdi 307 last error with elm327 passed glow plug error gave last year compared to last year the car worked harder in the cold this year we saw -18 degrees this year in & nbsp; i think there is a problem in one or more of the glow plugs in my car is a bit difficult to reach. behind
08.05.2020 16:38 # 6
Bugra
[QUOTE = Inceyasar] buddy glow plugs are working under -4 degrees I know. i have 1.4 hdi 307 last error with elm327 passed glow plug error gave last year compared to last year the car worked harder in the cold this year we saw -18 degrees this year in & nbsp; i think there is a problem in one or more of the glow plugs in my car is a bit difficult to reach. [/ QUOTE]
my friend glow plug is not the primary element of the vehicle's ignition system? Isn't it the element that performs combustion in the combustion chamber in cylinders? How does this important piece work just below -4 degrees? Diesel engine preheat indicator lamp that lights when the vehicle you are talking about turns the ignition on cold. it burns - in degrees.
If I have a mistake, let's find out the truth.
08.05.2020 16:38 # 7
[QUOTE = bugrature]
my friend glow plug is the main element of the car's ignition system? Isn't it the element that performs combustion in the combustion chamber in cylinders? How does this important piece work just below -4 degrees? Diesel engine preheat indicator lamp that lights when the vehicle you are talking about turns the ignition on cold. it lights up - in degrees.
If I have a mistake, let's find out the correct one.
A little confusing ". The glow plug is used to heat the diesel in cold weather. Combustion injectors occur in the cylinders.
koliva 2012-03-15 12:21:04
08.05.2020 16:38 # 8
Bugra
[QUOTE = koliva] [QUOTE = bugrature]
my friend glow plug is the primary element of the vehicle's ignition system? Isn't it the element that performs combustion in the combustion chamber in cylinders? How does this important piece work just below -4 degrees? Diesel engine preheat indicator lamp that lights when the vehicle you are talking about turns the ignition on cold. it lights up - in degrees.
A little confusing ". The glow plug is used to heat the diesel in cold weather. Combustion injectors in the cylinders will be possible.
heh teacher now. thank you.
08.05.2020 16:38 # 9
cey cey
If the car starts to hit the first starter, the saddle will run and if it gets too late, there may be a problem with the glow plugs.
08.05.2020 16:38 # 10
istanbullu_3886
it looks like pp2000 my spark plugs break out but this year it was so cold but it worked in a single starter
