Glasses and thermometer do not work.
08.05.2020 15:22 # 1
bestfear
As you know, we broke the last tiger ... After the repair, the vehicle did not work first ... There was a problem with the brain ... After long efforts ... They called the car last night.
* The windows of the vehicle do not go up and down regularly ... even the right window is completely locked ... the accident worked once and for all, it went down, it remained open, it did not move again ... The rear windows cannot be controlled by the driver ... the driver is stuck on the glass ...
* The car's outside temperature indicator has failed ... Why does this cause ...
08.05.2020 15:22 # 2
I think you should get the vehicle back where you got it and say it. Before you go, try all the equipment in the car and report those that are not working.
08.05.2020 15:22 # 3
bestfear
It finally happened that the malfunctions were related to the brain ... they tied the computer, thank goodness ...
08.05.2020 15:22 # 4
ErcaNKarsI
brain output manhood is broken: D: D
