Glass water spray problem
08.05.2020 15:53 # 1
ekinoks44
Hello .. I forgot to put water in the glass water sprayer. When I pulled the handle, the small amount of water at the bottom came. Then I stopped the car and filled the tank, but now I have tried several times, but the glass does not spray water. I did not understand if it made air or the dirt was blocked in the hose mouth. How do I solve this? When I pull the lever, the engine sounds but there is no water.
ekinoks44 2011-07-23 23:12:21
08.05.2020 15:53 # 2
alisuat
did not flow back under the vehicle or something, I think the pipe was clogged otherwise
08.05.2020 15:53 # 3
Poke the exit point of the water with the needle a little. It usually clogs from there. Mine was the same the other day. I fixed it with a needle.
08.05.2020 15:53 # 4
Pour half a tea glass of cola into 1tas of boiling water and remove the sprinkler in the picture and throw it into boiling water with cola. Let it stand for 1-2 hours and clean it with compressed air when it is removed. If you cannot find compressed air, blow it into the water inlet (Wide bore) hole of the sprinkler.
mustiii 2011-07-24 02:58:53
08.05.2020 15:53 # 5
There are thin pipes under the hood, hit the air at the joints.
08.05.2020 15:53 # 6
ekinoks44
Since the part we put water on the wipers has no cover, sand has entered the wiper motor and the sprinklers. We gave the air or something did not help. We changed the wiper motor, 2 sprinklers and we took the cover, we gave a total of 70 TL. It seemed like I gave it a little bit too much, but anyway.
08.05.2020 15:53 # 7
sprinklers clogged problem it
08.05.2020 15:53 # 8
Is it easy to take off and put on this part you mentioned? After we disassemble it, we don't have it.
[Q
OTE = mustiii]
08.05.2020 15:53 # 9
I have a close problem too, the water does not come in enough pressure, I wonder if my holes are clogged in it?
08.05.2020 15:53 # 10
[QUOTE = mustiii]
okdar what are you trying to fix mustafa por solve instantly
08.05.2020 15:53 # 11
Ako06
70 TL is a bit like it. anyway now
