Glass Water Does Not Squirt
08.05.2020 20:43 # 1
umitkc
Hello, Aleykm Friends.
The Glass Water of My Vehicle Does Not Squirt. The engine is running. but water does not come to the pipes. There is also water in the water tank.
08.05.2020 20:43 # 2
The fountains are calcified, my brother, I say hungry with a pin. It arises from the constant use of water in the summer. In the summer, take antifreeze glass water, add 5 liters of 5 liters of water, add 1 liter of water, add normal water, so that there is no calcification. In the winter, I use full glass water. Remember, if it cannot be opened, remove the horn from the pavement sprinklers with a pin and check the water. If there is no water, it is necessary to replace the glass water engine or disassemble and clean the tank. at the bottom of it, as deposits form over time.
08.05.2020 20:43 # 3
GokhaN
hello hi
If there is no water coming to the pipes, you should check the fuse if the engine is running.
08.05.2020 20:43 # 4
umitkc
Yesterday I checked the engine after the pipes .. The water was not coming to the pipes .. I tried the hoses by pressing the air .. The hoses were hungry .. The engine also had sound .. It works .. But it doesn't flood again. I blew the air to the engine, but it doesn't say you are my ban ..
08.05.2020 20:43 # 5
then my teacher says that there is a problem in the engine, my teacher is stuffy. you will probably need to change
08.05.2020 20:43 # 6
umitkc
I guess I'll change .. Thank you very much (:
08.05.2020 20:43 # 7
By the way, my teacher is 207 in your vehicle or you have entered 207 in your 306 profile. Smile
08.05.2020 20:43 # 8
umitkc
I sold my 207 vehicles and now I have 306 vehicles (:
08.05.2020 20:43 # 9
hmm then your water jet pump is cheaper bro Smile
http://www.peugeotmarket.com/peugeot-306-sılecek-depo-motoru,pr-1168.html
08.05.2020 20:43 # 10
umitkc
I realized later that you scored as 207 .. I looked 30 net TL.
08.05.2020 20:43 # 11
ismailkaya
There is an additional apparatus attached to the front and rear hose attached to the engine. There is mud. The plastic apparatus such as the check valve does not perform its function from the mud. When installing it in the place you take it off, put the gasket first and then put the motor
08.05.2020 20:43 # 12
umitkc
there is already one apparatus. I dismantled it .. I kept air in it. I put it back in place .. but my problem is not solved. My vehicle is now 306.
