glass water
08.05.2020 16:57 # 1
muhammed43040
I have 307 cars glass water fountain does not work at all. 111; ne ">
08.05.2020 16:57 # 2
Serkan
Either the fuse was blown or the sprinkler engine was broken, I bought the 206's sprinkler engine for 15 TL, and I gave it to the electrician in 5 TL. show it to an electrician I think
08.05.2020 16:57 # 3
muhammed43040
we already change 206 307 some parts are the same build room is the same we get saved
08.05.2020 16:57 # 4
ahmetismet
teacher I have the same problem, but the water in me & nbsp; When I put it, it flows directly down. I do not know if the warehouse has been displaced or the pipe has come out. I will take the sin to the service anyway.
08.05.2020 16:57 # 5
Serkan
[QUOTE = ahmetismet] teacher I have the same problem, but the water in me & nbsp; When I put it, it flows directly down. I do not know if the warehouse has been displaced or the pipe has come out. I will take it to the service whatever sin is going to see .. [/ QUOTE]
Sir, there is a gasket in the place where the engine is attached to the drum next to the water canister, probably there is a problem.
black piece sprinkler is missing the engine from the gasket.
08.05.2020 16:57 # 6
pierson
no water comes out from the sprinkler on the left side. how can i clean it ..
08.05.2020 16:57 # 7
[QUOTE = pierson] no water comes out from the sprinkler on the left side. check it
08.05.2020 16:57 # 8
vbmaster
[QUOTE = pierson] no water comes out from the sprinkler on the left side. The problem kept gone largely ...
08.05.2020 16:57 # 9
pierson
There is nothing in the hose because it comes with a lot of pressure from the right.
08.05.2020 16:57 # 10
vbmaster
as I said, it will hold air. it will disassemble the first dispenser of the hood and press it from there. largely resolved ...
08.05.2020 16:57 # 11
[QUOTE = pierson] there is nothing in the hose because it comes with a lot of pressure from the right water ... I tried to clean it with a needle ... it didn't help ... I wonder if I put it in hot water? [/ QUOTE]
then obviously lime inside is slightly clogged. use descaling agent with hot water. Be careful not to damage the descaling paint. & nbsp;
regulation: there are also those who recommend vinegar for congestion.
hLL 206 < / editID> 2013-05-25 22:47:59
08.05.2020 16:57 # 12
pierson
so let's put vinegar in the water tank or descaler ...
08.05.2020 16:57 # 13
[QUOTE = pierson] so I put vinegar in the water tank or descaler ... [/ QUOTE]
I don't think of any other solution.
If your English is a little good, take a look at the site below.
http://www.wikihow.com/Troubleshoot-a-Windshield-Washer-Pump
< p>
good method to squeeze air & nbsp; "Thumbs hLL 206 2013-05-25 23:02:52
08.05.2020 16:57 # 14
http://www.videojug.com/ film / how-to-clean-windscreen-washer-jets
http://www.ehow.com/video_4958678_winterizing-car-adding-wiper-fluid.html
http: //www.ehow.com/video_2326794_checking-car-windshield-wiper-fluid.html Reviews
