Glass vapor
08.05.2020 20:08 # 1
Coyote_carlos41
Friends, I wipe the windows of the 2004 partner vehicle, it is clean, the heater heats up and dries well, but you did not know about 45 minutes, the glass starts to evaporate again after an hour.
08.05.2020 20:08 # 2
OguzhanKucuk61
Moisture and moisture inside the vehicle may cause this. We are in winter. I recommend "cat litter" that I have seen on Youtube and after the confirmation of my son Soner. Put the cat litter in an old sock and tie his mouth. Then put the other one on the sock. Tie it up and place it under the seat. It is said to work. oguzhankucuk61 2017-01-17 20:35:27
08.05.2020 20:08 # 3
Coyote_carlos41
But a sticky-type vapor is formed on the glass.
08.05.2020 20:08 # 4
OguzhanKucuk61
Gee. I don't know, hodja. If you want, try the method I said. Although not sure, there is a possibility that it will work. The simplest method without intervention in the vehicle looks like this. I do not think of anything else. If there are friends who have experience, they will definitely help. Get well soon
08.05.2020 20:08 # 5
Gokcesel
If you wiped your glasses with a dirty cloth, it also has a lot of effect. Clean the most clean with camsil + newspaper paper.
This is the first time I am hearing the cat litter event.
08.05.2020 20:08 # 6
Coyote_carlos41
Well, neither the camsil newspaper nor the screen cleaner remained, but still the same first steam is heating the heater, you did not know about 45 minutes. 1 hour later, a greasy steam is formed on the glass. Coyote_carlos41 2017-01-18 14:47:41
08.05.2020 20:08 # 7
fkundak
Glasses with Isopropyl Alcohol ...
08.05.2020 20:08 # 8
Coyote_carlos41
I have not remembered that you mentioned a substance used in the cleaning of computers and LED TVs, I tried it with it, but the result is the same.
08.05.2020 20:08 # 9
teacher did you check the pollen filter?
08.05.2020 20:08 # 10
Coyote_carlos41
I just changed it is not even 1000 km
