Glass side lifting problem on the driver's side
08.05.2020 20:03 # 1
pepecura
Good Morning
yesterday it happened to me 4-up glass lowering keys on the driver's side broke down, the glass of the driver was just lowering, it was lifted when it clicked a few times, I removed it, I cleaned it well, this time it is just downloading it, there is no lift up on the 4 windows :)
Should I buy a new one?
pepecur to 2016-12-05 10:16:37
08.05.2020 20:03 # 2
Exactly, I would like to buy a new one, the original industry is around 300 TL, and the sub-industry is 85 TL.
08.05.2020 20:03 # 3
pepecura
Yes, I looked at the prices, I need to change right and left. Does anyone use side industry to see my business?
08.05.2020 20:03 # 4
SCREAMN
I had a problem with my keypad, I want to open it closes, I want to close it, it does not open, it was working according to the head, it was cleaned, it was worse as you said it was removed again, I disassembled it a little more carefully, it was fixed, I think I could not sit the keys exactly, I think it can be the same thing.
08.05.2020 20:03 # 5
SCREAMN
Is there any possibility of damaging the socket that completes the circuit for removal or check your socket before giving money to the part?
08.05.2020 20:03 # 6
pepecura
yun all day was in my hand I pressed vd40 I got cologne and got freckled, freckled :)
But as you said, the trouble of fitting it, I do not understand how it was seated, which makes the tire part big. but not only 1 but 4 on the window would just be knocking on the door, if I couldn't lock the doors from the remote, the windows would remain open.
08.05.2020 20:03 # 7
SCREAMN
The fact that all 4 windows do not come down may be related to the socket. If the socket is intact, there is a possibility that it may be broken while deleting the circuit. it can be a very difficult coincidence. screamm 2016-12-05 11:48:40
08.05.2020 20:03 # 8
pepecura
Yes, I think only 4 of them broke down when it got hot. it may be confused, it was not possible with a single button.
anyone doing a reset? have i done right?
pepecur to 2016-12-05 12:46:09
08.05.2020 20:03 # 9
fætih
Get a silver conductive paint. Apply to the black dots under the buttons with a toothpick. it will last. It is 10 15 lira paint.
08.05.2020 20:03 # 10
peco307
Hodja, the most robust is to buy 80 TL, there is no problem in the sub-industry. I use all the windows opening and closing.
08.05.2020 20:03 # 11
pepecura
[QUOTE = fætih] Get silver conductive paint. Apply to the black dots under the buttons with a toothpick. it will last. It is 10 15 lira paint. [/ QUOTE]
teacher, which one do you say here?
http://www.yesilkoyelektronik.com/104-iletken-bo to
08.05.2020 20:03 # 12
pepecura
[QUOTE = peco307] Hodja, to buy the most solid 80 TL, there is no problem in the side industry.
yes, I found it for 85 TL, but I did not see the piece, do I grin in color with other black pieces?
08.05.2020 20:03 # 13
SCREAMN
https://tr.aliexpress.com/item/for-peugeot-307-car-window-paillette-lift-switch-decoration-stickers-lift-push-button-trim-6pcs-per/32335840980.html?spm= 2114.010208.3.323.9azqzt & ws_ab_test = searchweb0_0, searchweb201602_1_116_10065_117_10068_114_115_113_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10099_10078_10079_10077_426_10103_10073_10102_10096_10052_425_10050_10051, searchweb201603_6 & btsid = b893b56b-c9b1-43cd-9f38-beb91d1e566f
08.05.2020 20:03 # 14
fætih
I would appreciate if there is an unused driver's hand with a glass opening button. the glass of the driver's button was broken, unfortunately.
08.05.2020 20:03 # 15
pepecura
[QUOTE = screamm] https://tr.aliexpress.com/item/for-peugeot-307-car-window-paillette-lift-switch-decoration-stickers-lift-push-button-trim-6pcs-per/32335840980 .html? 2114.010208.3.323.9azqzt & ws_ab_test sPM = = searchweb0_0, searchweb201602_1_116_10065_117_10068_114_115_113_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10099_10078_10079_10077_426_10103_10073_10102_10096_10052_425_10050_10051, searchweb201603_6 & btsid = b893b56b-c9b1-43cd-9f38-beb91d1e566f
it sells only the metals at the tip.
Also, last week, I got a hangover. I don't think I will get much from abroad anymore. Thank you, my friend :)
08.05.2020 20:03 # 16
SCREAMN
pardon I did not pay attention, I sent it when the price was very affordable. I know that the price is more than 75 dollars.
08.05.2020 20:03 # 17
Actually, the border is $ 100 friends. Returning products under $ 100 hang out because the customs officer sees the price of that product higher. But as our friend said, there may be problems with single products over 75 dollars. I have made more than 150 purchases so far, only 1 of them has not received my money back.
08.05.2020 20:03 # 18
pepecura
There is also a waiting and not to disappear, to read the wrong price etc. etc. :)
thanks friends
pepecur to 2016-12-07 15:10:37
08.05.2020 20:03 # 19
ARDADOGAN
I bought the supplier industry, it took no money for 6 months, but it was a failure, but we are getting the supplier industry because of financial problems.
08.05.2020 20:03 # 20
pepecura
how did it fail?
Page : / 2
