glass roof blinds
08.05.2020 16:42 # 1
seta2002
Good afternoon friends 206 I have a problem with the sunroof of my car, I want to change the feet of the glass but I could not insert the glass.
08.05.2020 16:42 # 2
ozaannn
http://forum.peugeotturkey.com/forum_posts.asp?TID=15041&KW=Sunroof&PN=1&title=206-sanruf-tamir-kiti-montaj-bitti
I use this link I did it myself, my friend wanted sunroof cu 100 lira
08.05.2020 16:42 # 3
seta2002
[QUOTE = ozaannn] http://forum.peugeotturkey.com/forum_posts.asp?TID=15041&KW=Sunroof&PN=1&title=206-sanruf-tamir-kiti-montaj-bitti
Take advantage of this link, I did it myself, my friend sunroof cu wanted 100 lira, I did it myself by inserting and inserting it [/ QUOTE]
& nbsp;
I looked at that link, but I could not remove the rear legs of the glass from the top < / DIV>
08.05.2020 16:42 # 4
rhcpeppers
it closes at the end of my closing, but it closes with the help of hand. I did not understand what happened with dust and earth or something. In addition, the windscreen-like piece that the Sunroof joins at the front stays high, not fitting. I handle it with the help of him. I do not understand what should I do, what should I do cleaning. & Nbsp;
08.05.2020 16:42 # 5
tazmaniac
When you press the button, there are rubber pieces of about 3e 5 thickness or 2 mm of rubber pieces in each foot to support the glass to stop the glass.
08.05.2020 16:42 # 6
seta2002
[QUOTE = rhcpeppers] when it closes, it closes with the help of the hand. I did not understand what happened with dust and earth or something. In addition, the windscreen-like piece that the Sunroof joins at the front stays high, not fitting. I handle it with the help of him. I do not understand what should I do, what should I do cleaning. & Nbsp;
08.05.2020 16:42 # 7
seta2002
When [QUOTE = tazmaniac] pushes the button, there will be rubber pieces of 2mm in thickness of about 3e 5 in each foot for the support of each foot to stop the glass. If the feet you mean are already my problem, I can't change the back feet. When I recovered the ceiling from the sprals, I pulled up one foot and when I was up, I got ten feet but I couldn't put the back. I inserted the ceiling filing, I changed the spral, I inserted the engine, I installed it, I couldn't do it "
08.05.2020 16:42 # 8
tazmaniac
yo not the feet, when you take the sunroof completely back, there are 2 plastic parts put in order to ensure that the feet do not come out of the sunroof, I am talking about them, you cannot remove the glass without removing them.
08.05.2020 16:42 # 9
morbeyaz
friends sanrof glass is in my hand ......
08.05.2020 16:42 # 10
xpyhre
[QUOTE = purplewhite] friends sanrof glass is in my hand ...... [/ QUOTE]
How much TL ` You're selling to Sister?
