glass roof blinds
08.05.2020 15:50 # 1
serkan24577
hello friends today when I went to work in the morning, I said a little sunrouf, let me open the air, I opened it a bit, it is not closing, our window remained open when we were trying to stay open 6 hours, it was strange. gotten :) fled 200 TL Koliva 2011-07-17 08:56:49
08.05.2020 15:50 # 2
Anyway, let's say it is late but there will be so many things: ((Kul structure will of course deteriorate
Maybe the sleds are forced out of negligence. The muscular side of the engine has been compelled ...
Sunroof is a piece that should be regularly maintained every year. When this is not done, the shoulder becomes shorter ...
the cecol 2011-07-15 19:45:42
08.05.2020 15:50 # 3
serkan24577
dude just because you never care well :)
08.05.2020 15:50 # 4
Yoksun ki a few months :))))))))))))))))
If you were here we would rob Embarrassed It's summer time to sunroof care ...
08.05.2020 15:50 # 5
F-Eren
I hope the cecoli will give me sunroof care, it is not worth it :)
08.05.2020 15:50 # 6
[QUOTE = F-Eren] I hope the cecoli will take care of me sunroof, I hope it is not worth it:) [/ QUOTE]
Not worth it Göz Kırpma You bought it early. Sırıtma
08.05.2020 15:50 # 7
tigerland
When it comes to cecoli maintenance, is lubrication cleaning done? me too engine zrolazing what should I do lately?
08.05.2020 15:50 # 8
Ah ah, even if he has a sunroof, his engine is broken. Dil Çıkarma
08.05.2020 15:50 # 9
tolga35
friends, I first cleaned my sun foof with a handkerchief, including the old oils on it.Then I lubricated it thoroughly with the WD40, I made the complete mechanism and a few times and I did not handle it for two days, so that I pour it into the oil well.Then I lubricate the working part of the sleds with liquid grease. It was good, but of course I did not know, I do not know my friend just said WD40 was enough ...
If there is a friend who has a clear knowledge about this, we can get more different recommendations, this came to my mind.
Meanwhile, the doctor's lamp is blessed, along with many lamps ...
08.05.2020 15:50 # 10
[QUOTE = tolga35]
WD-40 is a very low lubricating product. In fact, it is used as a more lubricant beyond the lubrication. However, it is sometimes used for this job since it leaves a very thin layer of oil behind. I did not find the WD-40 spray to the sunroof mechanism suitable for my own mind. Because the fine oil that he left behind will dust in time. It also absorbs grease or dust in the same way. If I were in your place, I would clean with WD-40 if it was too old, dusty, wasting oil. Then I wiped it with a clean cloth and then lubricated it with a dust-free product like Teflon spray.
08.05.2020 15:50 # 11
tolga35
WD40 did not satisfy me too, so I sprayed liquid grease.
08.05.2020 15:50 # 12
F-Eren
old singer sewing machines had oil in the plastic bottle or I think it should be used from it all the panacea: D
08.05.2020 15:50 # 13
[QUOTE = Erbin] When it comes to cecoli maintenance, is lubrication cleaning done? me too engine zrolazing what should I do lately? [/ QUOTE]
Yes, good cleaning and lubrication :))
08.05.2020 15:50 # 14
tigerland
yaw cecoli washed the car this evening sunroof is difficult to shut down, engine is having trouble. What would you say if I wd 40?
08.05.2020 15:50 # 15
tigerland
You can http://www.uzmantv.com/aracimdaki-sunroof-calismiyor-neden-ol
helps everyone build :))
08.05.2020 15:50 # 16
[QUOTE = tolga35] WD40 did not satisfy me too, so I squeezed liquid grease. [/ QUOTE]
Silicone-based oils should not be used once because white residues are left behind over time and become equivalent to dust. It is not good to use direct grease. But there are also tourhouses of grease oil. Lithium grease is generally used for these works. The Teflon spray I am saying is water as in the picture, but there are also different teflon sprays produced by different companies.
08.05.2020 15:50 # 17
tolga35
thanks koliva this was something different, they should have bought the liquid silicone of würt, but i will take it from here it made sense
08.05.2020 15:50 # 18
serkan24577
[QUOTE = Berkay] Ah ah if I have a sunroof but his motor is broken. Dil Çıkarma [/ QUOTE]
Well, it gets worse when it breaks down untimely
08.05.2020 15:50 # 19
Well, my brothers, when my sunroof is half open and on the way while driving on the road, the sound of a tiny little glass sounds, so I stop it.
I shake the glass, but it does not play at all, so there is no gap.
creaking in the middle when opening or closing the bidet ???
How can I handle these? If I go to the service, do they get a lot of maintenance money or is there a place we can get out of service?
08.05.2020 15:50 # 20
Anyway, let's say it's over again.
Page : / 2
